Hey people,
Terry (one of the Execs for SAU-NSW) has put on a few excellent events in the past, including cruises for the 10th Anniversary of the R34 and 21st Anniversary of the R32, amongst quite a bit of other stuff.
Previous events have included media coverage on Motive DVD and in PI (or HPI or whatever it is now) magazine, as well as a few articles in the motoring sections of Sydney newspapers.
Basically Terry and myself would like to know how many people would be interested in having an event for the 15th Anniversary of the Stagea. It will be NSW-based, but everyone who can make it will be more than welcome to come along.
So, throw some ideas around and we'll see if we can get the ball rolling!
https://www.sau.com.au/forums/topic/366043-stagea-15th-anniversary-event/
  • Replies 144
count me in and make it a sunday ;) thats my day off a week.
and for gods sake, dont host it out back of west sydney or anything (penrith or blacktown area), make it a nice cruise to somewhere nice, like a sydney to canberra or small-medium cruise like sydney to wollongong.
How would this sound as a proposal?... :action-smiley-069:
Date:- Sunday 2nd October on the long weekend (but a week before Bathurst races). It's also the 1st day of Daylight Saving.
Time:- 10am > Leave at 11am
Meetup:- Top Secret Imports 36 Forge St Blacktown with only Stageas lined up along the outside of the sweeper up to Top Secret itself, for photography purposes
Sponsorship:- Top Secret Imports (but they're only discussing it at this moment - but plans can be changed if we're rejected)
Destination:- West Head at the end of West Head Rd, Ku-ring-gai Chase National Pk.
Overview:- West Head Rd is newly laid out hotmix tar, with a great lookout at the end. Electric BBQs.
It would be busy there on a long weekend with parking spots along that stretch.
UHF radios are an advantage so that we can gradually fill up the carpark at the end in due course.
Other ideas are welcome!
I've got to laugh about Cordeaux Dam...
When I was 17 and Treasurer of a different organisation, I set up a mystery tour to Cordeaux. It's a great spot!
Yes, let's consider that one too.
If we get a sponsor, then they might offer collateral for prizes. If I had a Stag - a powered up Stag - or a great looking Stag; I wouldn't knock back a prize/trophy.
Will consider Homebush Bay.
Will need to do a Recon anyway.
Thanks for offering help Nick, Ben, Dale, Ryan :thumbsup:
Queenslander
I would be keen for this to drive down for the weekend
I am sure we could get some more from this side of the border
(any free accommodation available??...hmmm last weekend of school holidays in Qld as well)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
