hi have issue with bnr32 with rb26 idling at 1200. sometimes more. i know the throttle butterflys have been cleaned and suspect that being the cause ( suspect, correct me if im wrong -_- )
looking for the best way to fix it , i can pull the manifold off ( time is money ) and spray the butterflys with TOMEI butterfly sealer ( if its still avaliable )
this approach is desperate ....
f**k the police, thanks in advance
https://www.sau.com.au/forums/topic/366541-rb26-idling-too-high/
Spray brake cleaner all around where the inlet bolts to the butterflys an make sure there is no air leaks.
Check and adjust the iac valve.
Check the adjustment on the throttle butterflys.
Then if still no good remove throttles and get tomei sealer from just jap
thanks dvsjez, checked my throttle butterfly adjustments. and after alot of swearing ive adjusted them to max close. made a difference of 500 rpm ( down tone rev, not up tone which is good )
does the IAC system use a temperate sensor ( known to be an issue? ) car randomly idles high sometimes ... sits at 11,500 -1200 normal idle ( -_- ) and creeps to 1,400 or more sometimes
how do i test this ? Cheers
Usually cleaning the AAC helps, but with BNR32's it's in an absolute prick of a location. I know when I start mine it flys up to about 1300-1400 and slowly die down to ~1000-1100 after 30 seconds
The ecu uses engine temperature and controls the iac to suit.
Cold start should rev up to 1300ish and drop down slowly as moodles said.
Also as he said its an absolute prick to get to.
Have u tried brake cleaner to check for air leaks to the plenum
IAC's usually gum up... Pull it off and clean him out.
Check you tb position sensor.
If no joy, try spraying carbie cleaner around all the gasket surfaces, stock gaskets blow out often.
If still no joy, whip off the mani (4 hrs) and re- adjust the tb's via linkages.. Use a molycote product (cant think of the exact product right now) around the edges of the tb's to seal. While you have the tb's off relace the side/shaft seals as these get old and dry- thus leak.
Good luck
J.
air leak could be from boosters as the one way valves die. and suck air in.
i blew tb shaft seals and idle went to 5000rpm. so i doubt its that.
check your pcv valve as mine also leaked. block the hose off and it will soon tell you. the plenum is a f**k to get off so, be prepared to get lots of beer into u.
if your in bris come round some time and we can rip it off, as i am pro at this now. lol.
look at charcoal can also as it has vacume lines attaached.
good luck
thanks for comments
throttle butterfly are fine, tb rod adjustments are max closed and fine ( except one rod, the ball joint is alittle kinked but fine )
throttle position sensor was replaced awhile ago but should be good ... meant to be adjusted at close to 0.1 or 0.5 i forget and when rev goes to infinity apparently ... does any1 remember what its meant to be
doubt air leak but may aswell check to be safe
car idles 1200 cold start .. after 20 or 30 minutes it creeps to 1300 sometimes 1400 if i drive it all day sometimes stays at 1400+ for a drive
think its temperature fault ? whats this AAC ? similar to IAC idle air control
Aac = auxilary air control.
Get a consult connected to test the sensors.
Set tps to .46V
Under the plenum there is the aac. Check i with a light. Using a phillips screw driver Wind the screw clockwuse to drop the idle down. Do this with the engine running
I suspect AAC valve, the one that has a 12mm (or so) hose going to it. They usually die after sometime, try blocking or pinching that hose closed and see if the idle drops.
Not sure where it sits on a RB26DETT, but on RB20/25s they sit under the plenum and connect on the side of the crossover pipe.
Hey i have the similar happening on mine but mines a rb25det
Mine idles on mostly 1200, somtimes 800 and other times 1000, its constant so not a huge problem.
when i had the standard computer it was fine, only when the power fc was installed so ive been assuming its just the computer that isnt perfect. Not sure if thats the problem in this case though.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
