having an issue with my clutch, put a brand new slave and master cylinder in my 33. clutch was perfect for around 600klms and then is started picking up right near the floor and now i can't even get it into gear.
just wondering if anyone knows what to look for?
my first opinion was air in the system, not being bled properly, but then it lasted 600klms..
anyone knows how to troubleshoot would really appreciate it..
Shane
https://www.sau.com.au/forums/topic/367029-rb25det-clutch-drama/
I would bleed the master and slave just to make sure there is no air in the system, or a leak. Did you replace the clutch line?
I know the master and slave are new but new doesnt always mean it will work. better off catching it now if thats what it is and claiming waranty. If you bleed everything and then its still the same then you probably have a clutch problem. If it works all good then gradually goes away again then you have a problem somewhere between your pedal and the clutch fork. Fork is moving, but may not be moving through the full motion
Well it sounds like your clutch hasnt started slipping, sounds like theres not enough travel to engage the pressure plate to disengage the clutch
so in that case.... some sort of pivot ball issue? I'm not sure what happens when the pivot ball fails, I know it leads to clutch issues. You could maybe grab a torch and pull the rubber boot for the fork aside and see if theres anything obvious. But I'm not sure how much you will see. How much travel does the slave have?
Did you adjust the freeplay in the clutch pushrod?
You may also have cracked the pivot on the thrust fork so that it will open up when the pedal is depressed, reducing the ability of the thrust bearing to properly disengage the clutch.
When you snap the pivot, the pedal will go to the floor and not come back up without help. Had to drive home like it was an 18spd road ranger box :laugh:
Yeah i had that happen to me recently and my clutch had only done about the same km's.. brand new.
I checked the pivot/fork, new slave+master.. everything appeared to be fine, so last weekend with a couple mates off came the box..
only to find that the pressure plate bolts where not done up, well i lie, 3 where.. 6 wherent.. so the plate was sitting on the piss...
Tightened them up and box back on, bam! no problems ;)
Who did ur clutch?
Who did ur clutch?
What the hell! Who did your clutch??
I should have known that lol...... Now that you've said it I feel like an Idiot for not remembering haha
I put some lube on mine when I put my box back in last time, no more squeaking, and the clutch feels a bit nicer :)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
