Hey guys,
Today we put thicker thrust washers in my diff and the wheels lock fine like I wanted, but when taking corners slow the diff clunks extremely loud. The wheels chirp which is what I expected but this clunk is unreal.
Is this normal?
Cheers in advance - Trent
https://www.sau.com.au/forums/topic/367137-shimmed-diff-now-diff-clunks/
Ive got a welded diff but there no clunks and that, it just skips and chirps esspacially when reversing on full lock.
The noise is the friction plates in the diff moving relative to each other. They clunk becuase they are tight (probably overly so in this case). The plates "unstick", move a little then stop again - hence the clunk which finds its way up the drive train. It can be a pretty aggressive thing.
A welded diff doesnt have anything to move so all you get is tyre noise.
Edited by djr81
yeah clunk like that is pretty common in clutch pack LSDs. not sure on a shimmed viscous though? but with a proper LSD it's what drj82 described and it can be so bad it feels like the rear subframe is about to fall out. just one of the joys of having a tight mech LSd (and apparently a tight viscous too it seems).
Sorry I wasnt paying attention & didnt realise we were talking viscous LSD's. If the thing is clunking that is pretty bad news & I would be rechecking clearances ASAP. The whole point of running viscous liquids is you dont get static friction "stiction" in the operation hence no clunking.
If only there was an antonym for thixotropic the world would be a better place.
If you actually read the threads properly, particularly my posts.. I said that when I first put 2x1.49 shims in it was TIGHT AS FK and was essentially acting like my 2-way in the Skyline. After a couple of weeks it had worn in to the point that I didn't notice it anymore, except on full lock reversing out of a parking space. Couple more weeks and it wasn't carrying at all but still lit both wheels very predictably.
Yep I have read the diff shimming thread bubba cheers, it appears that the clunking is getting less frequent. Is there any chance I have a clutch pack LSD? Or is it more than likely I've f**ked up somewhere? Thanks for all your input guys
Cheers - Trent
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
