Ok so i have an r31 with an rb20 gearbox in it, the rb20 box was rooted and clutch was faaaaarked so i went and spent all my
money on a 5 puk ceramic cutch and wicked pressure plate to help out with the power im planning on making
heres the issue I did soooo much research called jap wreckers to double check and everyone said the SR20DET gearbox was identical to the RB20DET gearbox
so all i had to do was change my current bellhousing and hey presto the car will live again...... so stupid me went out and got and SR20 gearbox.........
and people NO it was not the same..... it LOOKS pretty close but the SR20 gearbox is 40mm longer.....
so now im stuck with a driveshaft that wont fit on my 31, poor me what to do i thought looked up some more info and apparently the auto driveshaft is 40mm shorter than the manual one
all u gotta do is change the actual bit that goes into the back of the gearbox to the manual one, the yoke or sumthin like that. anyway had a look and NO WAY
the caps on the manual are smaller than the ones on the auto so the yoke thingy wont transfer over :down:
i was told my only other option was to get it cut welded and balanced, but i didnt want to do that untill i got an RB25 gearbox to match it up right away
so does anyone hav any advise? im really stuck
https://www.sau.com.au/forums/topic/367432-gearbox-pickle/
the reason i didnt buy and rb20 is because they r way too expensive for what they are, and i want to get an rb25 box anyway the sr was just to get the car moving again.
unless u know where i can get a cheap rb20 box?
https://www.sau.com.au/forums/topic/367432-gearbox-pickle/#findComment-5861516
Oh man, if only one of us had come across this problem just days earlier. Only 2 days ago I paid a mechanic to swap my SR20 bellhousing onto an RB20 gearbox I got cheap and only once it was bolted to the engine we found that it was 50mm shorter. What a waste of time, it's not worth getting my tailshaft lengthened so I'm shopping for an SR box instead. I drove 5 hours return to look at one today that was f**ked.
So for the search record:
CA18 and SR20 gearboxes are the same length
RB20 are shorter!
https://www.sau.com.au/forums/topic/367432-gearbox-pickle/#findComment-5861784
well the cheapest in SA currently is 500 and for a temporary gearbox thats just way too much, call any jap wrecker in sa and they all want 6-800 depending on condition of the box
the box i really need is RB25DET which i could pick up for 1000 so paying half that amount for a box im only gonna use for like 1000km just isn't cricket
and i stress the word again TEMPORARY i dont need to keep this gearbox i just need to get around in it untill i have the 25 box and associated bits to fit it to the 31
and god id love one from SA which costs 350, seriously id go and grab it tonight to stick it in tomorow, so if u selling a RB20DET gearbox in SA for 350 send me a msg and ill grab it....seriously
https://www.sau.com.au/forums/topic/367432-gearbox-pickle/#findComment-5862122
if you only need it temporarily why not just hang off, save that little bit extra and fork out for the 25 box?
+1
stuff pulling the gearbox out twice when you dont have to......... Just save for the 25 box if you can get one for $1000
https://www.sau.com.au/forums/topic/367432-gearbox-pickle/#findComment-5862273
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
