So, im wondering if anyone knows any good spots for taking some photos of my car?
and I mean public areas that have nice scenery in the background and such; not somewhere like my driveway, which is crappy.
So far I've been to Stromlo, since i live near there. Its pretty nice
so, suggestions...
https://www.sau.com.au/forums/topic/367761-photos/
I have got lots of places in mind. I haven't had the chance to take photos yet tho.
- Alleys or against walls with graffiti. There are a few around.
- Government house
- ANU
- Various schools
- Scrivener dam
- Roads here and there, depending on what colour your car is.
https://www.sau.com.au/forums/topic/367761-photos/#findComment-5865780
Assuming they're still out there the older hangers at Fairbarin were a good spot to take photos a few years ago. Another spot is down near Questacon or even on the lake side itself along that one way road who's name escapes me.
Also depends on what kinda of image you want to have with your car? Are you going for the JDM Jap look, the street cred/ricer-boi look (where graffiti walls would be good) or for a classier look (where Govt House/Boat shed would be good.) Taking a picture isn't always as simple as point-click.
https://www.sau.com.au/forums/topic/367761-photos/#findComment-5867130
I took some pics of mine in a hangar where I work, PM me and I might be able to arrange for 1 or 2 people to drive in take some pics and go. It is dependant on the people who are in charge on the day but can be arranged.
http://i1143.photobucket.com/albums/n626/rig136/IMG_0834.jpg
hope the link works
Edited by rig136
https://www.sau.com.au/forums/topic/367761-photos/#findComment-5871610
hope the link works
hhmmm... I've been in there before! Would be really cool to have the BBJ or Challenger in the background :whistling:
https://www.sau.com.au/forums/topic/367761-photos/#findComment-5872196
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
