Ok just to get EVERYONE on the same page ( I have already spoken to a few members) in regards to discussion about SAU affiliation, stickers/merchandise, branding etc its something I've already looked into previously and looking into again for the benefit of the Tasmanian SAU community.
Now like everything there are advantages and disadvantages in doing any of the above and anything that is done needs to be done within the guidelines of the forums and/or club guidelines and done once and officially.
This being said Im waiting on confirmation if Tasmania are able to run with SAU affiliation as a club without having to be CAMS affiliated and if so what guidelines would be in place (as Western Australia do) and what we are/aren't able to pursue as a club.
I will add more to this topic later and really interested in what everyone has to say but until we have conformation of what we can do, I ask all members to stop with the threads/posts regarding all items mentioned above.
Cheers Ben
/Admin hat on
If Christian (Prank) was contacted via PM about this he wouldn't have seen/read it. I emailed him direct, Christian gives a big YES.
SAU has no issue with you blokes forming a club, using the SAU logo if you want to incorporate it into a SAU-TAS type of logo/sticker/branding etc etc.
If you need anything moving forward please contact myself directly. Christian is happy to let me run/help you guys with anything you need from the SAU side. He doesn't need to be involved unless i see reason.
I rarely check the TAS section but if you need me, just PM me a link to the thread and i'll do my best to 'read up' when i get a spare few mins.
Good luck :cheers:
  • 1 month later...
  • 11 months later...
  • 7 months later...
  • 2 years later...
Basically nothing happened after the stickers as pretty soon after the community went quiet, I haven't seen anyone post for a fair while. I'm back in Tasmania now though, would be great to see this kick off again!
  • Like 1
  • 1 year later...
Is anything happening with this?
Also if we want to join a CAMS club so I can do local practice days etc, should I join SAU Vic or NSW? Or just join a random local club? I'd rather just be in SAU and nothing else (via the above-mentioned SAU Tas stickers + a formal membership in SAU VIC/NSW for CAMS reasons).
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
