  • Replies 70
Yeah dude, if you're going to make a technical statement online. You'd better have your MOFO scientific calculator and text books on hand !
Nah, I'm sorry about the technical rant, just wanted an excuse to draw a pretty picture
https://www.sau.com.au/forums/topic/368395-m35-2jz/page/3/#findComment-5880966
*sigh*
Obviously a generic form that they fill out.
Just so as we are clear, in no way am I advocating that I would prefer a "Rotah" over a "Motah" (lol), but I feel you guys needed to understand that not all rotors are without torque.
https://www.sau.com.au/forums/topic/368395-m35-2jz/page/3/#findComment-5881150
Was gonna say...4L displacement and only puts out ~200kw...:sick:
yeah by RTA regulations its classed as a 4Ltr and as we all know jap cars are all restricted to the 206Kw so that doesnt really mean anything either in terms of how good an engine is and what its capable of..........
https://www.sau.com.au/forums/topic/368395-m35-2jz/page/3/#findComment-5881271
Ahh yeah just read up on the engine classing on Wiki...makes sense now...:blush:
https://www.sau.com.au/forums/topic/368395-m35-2jz/page/3/#findComment-5881298
How many people actually think 206 is a real power figure. Lancer evo states 206 but have been stock dynod at over 300. And my stag did lose against a newish one. Isn't the 206 just a regulation in Japan so they just out that so they can avoid legalities.
https://www.sau.com.au/forums/topic/368395-m35-2jz/page/3/#findComment-5881881
Stock dynoed at 300HP but not KW.
My old Evo 8MR was 225kw stock. After mods it was close to 300KW at all 4 wheels. TBE, Profec B II ( 1.65bar), Ecu, Fuel pump ect.
I'd be interested to see the stock dyno of the VQ25det, I recon 206-210 would be pretty darn close.
Edited by ArdentEagle
https://www.sau.com.au/forums/topic/368395-m35-2jz/page/3/#findComment-5882121
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
