Hey people, :wavey:
I need to buy myself some real tools.
My Kmart cheapos have started snapping.
Is the Kmart Motopro brand ok?
Just want something better quality than the $20 sets but dont' need the $500 set.
What do you guys recommend?
(i did search but didn't find much)
Thanks..Birnie :bond:
https://www.sau.com.au/forums/topic/36921-tool-kits-for-maintenance/
No idea, but I would never be without my snap-on spanners :D
Sidcrome were good, until they turned cheap and nasty.
Sumo
I second that... I broke a Sidcrome breaker bar and a Sidcrome ratchet today on a really nasty gearbox oil plug...
Going to buy a bigger break bar tomorrow... And a new gearbox plug... :D
I got a snap on tool box for my 21st and have slowly been building it up. The way I see it, if you look after your tools they will last for life (if they r good enough)... i will also love cars, and work with them for the rest of my life.. so why not invest into some decent stuff so you never need to replace it again.
Where I used to work all the guys had snap on apart from the younger guys who got kingchrome cos they are a fair bit cheaper.. bit still pretty good qual.
Yeah, i guess i'm going for a bit for more of a cheapy as i don't know that much about cars and do pretty minimal amount of work on them.
The plan is to learn more and more and I'm getting there slowly.
The Kmart Motorpro had a 230 piece set for $199.
Had heaps of stuff in it in a 2 draw set
Look for a probably a full set of 3/8 sockets, a set of metric spanners, and a 1/2 inch drive breaker bar or rachet (for servicing). That would be the very least, To get to the spark plugs (removing the 2500 Twin Cam cover) you will also need allen keys. These basic bits should get you through just the very basic self maintanence.
Quick follow up....
I did a look around at everything awhile ago just to get an idea and was suprised how expnsive things can be and just let the idea slide for awhile.
But yesterday, the Motopro ones for $199 had been reduced to $129 so i bought them.
Heaps of stuff. Don't think the quality is right uip there but it looks ok.
Has 3 different sized ratchers, sparkplug sockets, allen keys and more plus a 4 draw chest to keep it in.
Just thought I'd pass it on in case someone else needs some quite cheap stuff.
The special ends very soon so I'd get in there if you want em..
Thanks....Birnie out
The main thing i noticed when i bought my Stanley tool kit, is how well the tool actually fits the nut etc, that its supposed to. Ie a 14mm open end spanner fits a 14mm nut with NO play in it. Cheap and nasty tools always seem to not quite fit and end up rounding off more nuts than they take off.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
