Could easily be original.
My old engine only recently came out, had never been apart or out in it's life. Not even a head gasket. I've raced the shit out of it for the last 3 years, someone else did before me, and who knows what it did before that since 1989....
Engine still had bore hone marks. Only thing that killed it was a big end failure..... I did a session of 30+ flat out laps in a Qld summer dicing with Group A cars, without an oil cooler. No doubt in my mind the oil would have been so thin it simply lost it's ability to lube.
  • Replies 209
Yeah maybe, but from what I have seen they would not look this good. I mean they really look as if the hone was just done. I moved the pistons side to side and there was little to no movement. The big end looks good too, so with a gasket kit and arp head studs it should be a nice motor.
You can make it flow more and still keep the air speeds up, like I said I am not just going to make the ports as big as I can. The good head builders here in the states do it all the time. Thats how you make the best power with a usable power band.
I have never seen a motor here with lots of miles and failing rings look so good. Most of the time they are real faint if visable at all. Really though it doesnt matter as I was not planning on reringing it unless the cylynder walls were messes up. No scares or scraps and plenty of hone left. Arps and a oem gasket kit and I think I am golden. The big end looks good too.
Anyone know if a oem gasket kit comes with a waterpump gasket? I have a new pump but no gasket with it.
Edited by Driftnuttz
well everyone was bagging the hell out of the 20 cause you cant get decent power with out spending endless amounts of money but it seems the RB24 isn't as bad as everyone seems to think and not as expensive as well considering people have been able to build these for 5-6k and brings on a turbo quicker than a 25
Fair enough, but a fairer comparison would be a rb20 dyno sheet then the same car with the bottom end swap rather than someone sliding around and kicking the clutch to make smoke.
Smoke isn't a fair indicator of power. :)
No, pretty sure they weren't. People were saying that spending the money in the right places made more sense than rebuilding / forging a motor that is already reliable and can make decent power up to a point.
No one said the 24 was bad, there are a few on here before who have already built them, with threads on results. The point was for the same 5-6K you can have a built 2.5 or 3lt with a lot more drive-ability and potential. Bringing the turbo on quicker is irrelevant...what turbo, what engine? GT40 on a 2lt vs a 2530? Right turbo matched to the right motor for the right job.
got a bit of "fulleh sic uleh" in that video.
What a wanker though.
I could make a commodore smoke like that.
Good luck with your "I'm a special kid" RB20 projects. When your wallets are empty, and you're crying because stock RB25s and RB2530s are lapping you, I'm going ot laugh my ass off.
from what i gathered maybe wrong and talking to people but wouldn't a RB24 bring on a turbo quicker than the 25 if both ran the same turbo? cause of the head isn't that the point of 25 head on a 30 bottom to make it more responsive? cause a 24 for would be forcing a similar amount of exhaust gas out as a 25 but through a smaller port there for increasing the velocity which the exhaust gas comes out...or am i way off?
haha couldn't see that happening as from what i've heard Roy's standard 20 can easily keep up with the "big boys" out on the track so much more a 24 could and i'm doing the 24 as a side project as a bit of fun and doing bolt ons for the standard motor i'm putting in atm and i'm not fussed bout 25's lapping me (if they can) it's all for fun and if you don't have fun with it then what's the point of doing it :thumbsup:
Edited by Forged R32
Yeah realise that but with slight port you could get them up to speed surely...??
Can anyone post up links to 24 builds can't seem to find them my eyes must be painted on lol
and has anyone on here done a rb24 ? Can you post setups and dyno figures and what kind of response driveability?
That is the whole point, porting a head usually decreases velocity and makes it worse down low.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
