Hey guys
Looking at getting a 3" metal core high flow cat to use in a new front pipe. Looked on Ebay and found the "BOKKA" and "KENOBI" 100 and 200 cpsi cats. They are pretty cheap going for under $200 delivered.
From what I can see most of the brands on Ebay appear to be the same cat from the same manufacturer, just badge with different names.
I know they more than likely arent ADR compliant and Euro emissions compliant like they say (not too worried about this) but I wanted to know if anyone has used them and what the quality is like. Im interested to know if the core has held together or started to fall apart.
Also are people going more for the 100 cpsi over the 200 cpsi? I found a flow test result from Cateran showing that a competitors 200 cpsi flows about 50 cfm less than their 100 cpsi. This would make the 200 cpsi a reasonable choice as it may help keep the exhaust slightly quieter.
Thanks guys
Edited by slippylotion
I bought the Bokka 100 cpsi one a little while ago. Was impressed by the quality, especially for the price. It remains to be seen if it lasts for 10 years or more...
Does it have a fitting for the cat sensor at all?
Na there no good as they are a 400 cpsi ceramic core. Not much better than a factory cat.
3 inch inside and will pass EPA testing, might cost you 1 or 2 kW unless you are running big power
At one stage I ran a 400 cpsi ceramic "high flow" 3" cat on my 180SX and it blocked up in 6 months. We couldnt work out why the car had lost a heap of power and couldnt hit high boost when it was on the dyno. Pulled out the cat to find it had half blocked. I wont run a ceramic core cat again after that.
Unbolt cat.. Smashed screw driver inside it... Bolt cat back up.. Hollow...
But I have a feeling Aus laws may not like this? In NZ as long as the cat is in place it's legal, they don't test emissions or if it's got its internals lol
I did this to the ceramic so called "high flow" cat in my 180SX and Hello power!
pretty sure it has to be above 200cpi to pass EPA. won't get hot enough otherwise, and the infra red thermometer won't detect a significant enough temp difference.
that being said, i'm so tempted to grab a decat pipe........ i've got a 3" catco, inspected it recently and it seemed fine - but hate knowing there is kw's getting eaten up in there.......that being said, it would not compare to how stupid i would feel if i got done by the cops/EPA for running an illegal cat setup - the fine alone would put me in debt for months.
I hear you. Luckily it looks like I have a functioning cat in the 180SX and I rarely drive it these days also. I do have a bolt in Jap 200 cpsi cat for it but just too lazy to bolt it in. I like the extra power of a hollow cat but dont like the increased noise of the exhaust.
I dont want the M35 to be like this!
+1..... never had a cat in a car for more than 10,000k
Any of you guys running a turbo back exhaust finding the boost increases over standard due to the extra flow?
Yep. Andrew promised around 3 pound and a significant power gain. I got both.
Mind you thats my impression. Hasn't been on a dyno... yet...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
