I have had my rb25 neo rebuilt and have discovered the joy of piston slap with forged pistons when cold. When they're cold there's like an 8 thou clearance from piston to bore to allow for mega expansion; it blows smoke and sounds like a diesel until it's warm (which generally happens by about the end of the street); I suggest there's no way the compression will be as high under these conditions, and perhaps it could even be a 25-50% difference like you're seeing here.
sounds like it was built a bit looser then it probably should have been.
nothing worse than piston slap, and it just gets worse... my first car ( cordia turbo) had it bad and even after a rebuild was still slapping away, if your very particular about your car it annoys you everytime you start it, i think all that rocking scuffs the piston and rings, and just accelerates wear and tear.. not to mention sounding like its a worn out engine....
Its very worthwhile to do that important work yourself or inspect it, cause what i thought was a good boring out of my block turned out to be a rough as guts quick job and resulted in piston slap and low compression on a rebuilt motor ( no forged pistons), rings wouldnt bed in and it was a mess...
all those measurements of a thousandth of an inch make big differences, and mechanics can be very rough and approximate instead of precise and exact...
the difference between a motor with perfect clearance and precision compared to others can be huge, sounds rough and dowy compared to sweet and quiet....
8 thou is pretty massive, why so big?
If it is blowing smoke when cold it means the rings haven't properly bedded in, this isn't right. 4 thou sounds better for a street car to me.
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
