Hi guys, ive searched around these areas but i cannot find a straight answer for which engine oil i should run in my RB25DE Skyline.
The car will be used on the street/daily and wont see the track (atleast for a while).
can you guys please recommend me which oil to use.
Thanks in advance :)
https://www.sau.com.au/forums/topic/369569-what-oil/
depends on how much you want to spend. all you really need though is a 10w 30 semi synthetic oil, although you could use a basic mineral oil if you were strapped for cash, but i'd stick with the semi. if you want to go all out you could go a full synthetic, but to be honest, for a natro skyline i wouldn't bother. as for brand, that is really personal choice and everyone will have and opinion as to what is good.
you could have a read through this thread for some opinions
http://www.skylinesaustralia.com/forums/topic/22458-the-goods-on-oils/
https://www.sau.com.au/forums/topic/369569-what-oil/#findComment-5890910
I remember I read that thread when I was looking for what oil to get... what a marathon
I use Mobil1 fully synthetic ... forgot the numbers but its in a silver coloured container
10w 30 im quite sure it is though
https://www.sau.com.au/forums/topic/369569-what-oil/#findComment-5890995
Any of the nulon range are good.
LOL^
I use penrite mineral 20 - 50 (60) Extra 10.
serves me well
but don't get their 20 - 60 stuff, i only use that thick cause my engines 33 years old.
Get the next weight range down or 2
Edited by Socrates
https://www.sau.com.au/forums/topic/369569-what-oil/#findComment-5891799
Yer im with Dan ive been using a full synth Nulon for the last two oil changes, seems to do the job quite nicely.
But yer in all honestly, and semi/full synthetic oil will be fine as Mark stated.
https://www.sau.com.au/forums/topic/369569-what-oil/#findComment-5893256
yer like dan said, any of the nulon stuff is not to bad. I use a full synth in my 25de and it seems to be ok i cant remember exact numbers, but in all honesty as mark said before any semi/full synth oil of the right grade will be fine, its really just comes down to what branding u prefer :)
https://www.sau.com.au/forums/topic/369569-what-oil/#findComment-5893260
thanks everyone for the help. so i should go ahead and get 10w 30 either fully synth or semi, in the brand of my choice. sounds easy enough :)
yer thats how i felt, just couldnt get a straight answer, plus everyone having different engines, eg N/A, turbo
https://www.sau.com.au/forums/topic/369569-what-oil/#findComment-5893272
10W30 recomended for RB25DE, i go with Valvoline Synpowers for my last service found it quite good and after 5-6 months still has the rich honey like color to it after 2300km of driving. However never 100% impressed im going to try Royal Purple, a friend with a S15 uses it and recomends it for japs cars so ill give it a go.
https://www.sau.com.au/forums/topic/369569-what-oil/#findComment-5893552
I Use mobil1 5w 50 .... planning to change on something else after the 100k service though
I only change every 6 months as well ... thats generally only about 5-6 thousand kms as well, i dont drive the skyline all that much .. its still very clean at the end of every oil change so i havent seen the need to change it more often
i think the motul stuff has been quite highly recommended as well
https://www.sau.com.au/forums/topic/369569-what-oil/#findComment-5893747
we use mobil1 at the moment cos my dads been using it since his good old days
probably going to try something else though maybe a 10w 40 or 10w 30 fully synthetic. i dont really change my oil often enough though, should probably go for something a bit cheaper but still fully synthetic and change it more often .. im paying about 80 bucks for a bottle of oil atm with mobil 1 and ive seen some castrols go for a fair bit less ... or even the motuls were going for a decent price ..
that thread on oils confused the hell out of me lol
https://www.sau.com.au/forums/topic/369569-what-oil/#findComment-5894915
I don't recommend nulon, mainly cause of the price. I believe cheap = cheap quality product.
I out nulon in the same basket as el cheapo gulf western.
lol, whilst I agree with you regarding how shit the Nulon oils are, Gulf Western's Sougi S6000 was every bit as good as Motul 300v (Group V Ester base stocks)... $60 for 5L too!
Just a damn shame they aren't making it anymore :(
https://www.sau.com.au/forums/topic/369569-what-oil/#findComment-5898097
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
