Not quite true... There were some improvements from the R32 to R33 evolution, especially in the ATTESA (4WD) system.
The ATESSA-ETS in the R32 model updated it's information 4 times per second.
The ATESSA-ETS in the R33 base model updated 20 times per second, and the ATESSA-ETS PRO system in the R33 GTR V-Spec updated 1000 times per second.
Also, the ATESSA-ETS PRO system in the V-Spec came with an "Active-LSD" in the rear, that proportioned torque electronically laterally between the two rear wheels, as well as longitudinally between the front and rear wheels. In the R32 GTR and base R33 GTR, the ATESSA system only controlled torque split longitudinally between the front and rear.
Another difference is the brakes. The majority of R32 GTRs used Sumitomo-brand 4-piston brakes. These came with 296mm x 32mm brake rotors. The very rare R32 GTR V-Spec 2 and the entire R33 GTR range were blessed with the famous Italian BREMBO 4-piston calipers and rotors measuring a considerably larger 324mm x 30mm. Thus, the braking system was VASTLY improved on the R33 GTR range.
People who claim that the R32 GTR is a better car are usually people who have never driven both the R32 and R33 GTRs, and are just dreamers who love talking about cars they've never owned. They spend their time quoting other people's opinions on the matter verbatim and pass it off as their own. They're just sheep. Don't listen to them.
The R33 GTR is between 30-60kgs heavier than the R32 GTR, depending on spec levels. With improved suspension geometry in the R33 GTR, this weight gain is negligible, and hardly noticeable unless you drive both cars back-to-back.
Here are links to the specifications of all three models of GTR:
http://www.gtr.co.uk/html/technical/r32.asp
http://www.gtr.co.uk/html/technical/r33.asp
http://www.gtr.co.uk/html/technical/r34.asp
Good luck with the assignment.
https://www.sau.com.au/forums/topic/36999-gtr-32/#findComment-739884
Good info Andrew!
But I still like my 32's cos the handling on the limit keeps you awake and they did win Bathurst....
even though the pack of arseholes didn't want it too. :D
Cheers
Ken
https://www.sau.com.au/forums/topic/36999-gtr-32/#findComment-740075
Good info Andrew!
Cheers
Ken
By no means am I putting down the R32 GTR. It was a legend for a reason.
All I'm saying is that take a step back and think about all the little kids saying that the R33 is a boat, and that it's SOOOO much heavier than the R32, and blah blah blah... They've most probably never even driven a GTR, let alone done a back-to-back comparison between them both.
There are good and bad points of both cars when compared side by side, but nowhere near enough to warrant the R33 bashing that some 16 year old kids like to partake in, because they read it in a magazine.
https://www.sau.com.au/forums/topic/36999-gtr-32/#findComment-740175
Hehehe.
You bite well and you should know that the internet is the home of the 12 year mechanical engineer.
Yes I do agree that people tend to follow the general consensus of opinion without even knowing why.
I like my 32's but a 33 got the closest to winning Targa Tas o/right which is better than a 32 has done , which to me is a better indication of a well handling road car, not a purpose built race car.
Anyway, I hope this helps Karen with her assignment..
Cheers
ken
https://www.sau.com.au/forums/topic/36999-gtr-32/#findComment-740191
Karen
Just a suggestion, but considering you're in WA, why not go speak to a few people around town. Ken, I can see you have your hand up (he's in Malaga), and am sure you'd spare a few minutes to allow questions to be asked and a couple of pics of the Targa prepped 32 you have.
Either than, or speak up in the WA section, I'm sure you could get Brett (EVL R33?) to give you his opinion on his R33 GT-R. And Micko will certainly help out with the R32 aspect as well.
Cheers
Brendan
BTW, if you check out my site, you'll find a little background section on the R32 GT-R there that may help out along with specs & photos on the R32 GT-R V-spec (1993) edition.
https://www.sau.com.au/forums/topic/36999-gtr-32/#findComment-742818
i think the reason why the 32 was put into the bathurst series is because it was bacially a race built car with plates on it. i read some info awhile ago can't remember where but it was that nissan made this car for the track. but in saying that i think any GTR is wonderful and i love them all!!!! :) have you guys seen the ZERO-R's made by HKS??? they are a R32 gtr with a new style bodykit, win exhausts, 2.8L HKS stroker kit, big single turbo, specially made 17' or 18's, no back seat, motobiker side filler for fuel, everything about this car is race SPEC, everything!!! if i can find the article i'll scan it in. they made 10 and only sold 2 because they were asking too much. now the 8 just sit behind the HKS factory with covers over them and moss growing on the bumpwer and the brakes rusted away.... so sad...:);):)
https://www.sau.com.au/forums/topic/36999-gtr-32/#findComment-743274
The R32 is not better then the R33 , the engine is not entirely the same ,
The R33 has newer and more stronger internals then the R32 , handles better,brakes better , aerodynamics are better and also it is more stable at higher speeds.
The R32 is just a car to have fun with at a low budget sorta thing :) .
The VSPEC R32's are pretty much the good R32's ;)
https://www.sau.com.au/forums/topic/36999-gtr-32/#findComment-743524
shit's all over the R33 any day... and u know it!
Let me guess.......... You own an R32? :stupid:
I'd ask how many R33 GTRs you've driven, but being the internet, you could just say 5000 and I'd have no recourse to prove otherwise sad2.gif
https://www.sau.com.au/forums/topic/36999-gtr-32/#findComment-744097
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
