that's great Martin, thanks for posting
so once ecu is remapped area under curve is pretty much the same
the 2011 has a stronger top end, could that be due to the larger turbo intake piping?
Same conclusion here. Once properly tuned they are almost the same.
The two cars output is so close due to the fact that they have a mechanically identical engine package and turbochargers. The MY11 has fractionally larger inlet pipes which at this level of tune dont make a massive difference, but do account for some of the top end improvement
Wow, those results are so definitive. Very much the case of holding back something when first developed so you have something to market when the new model is released. We'll have to call it the new "Apple iGT-R" :nyaanyaa: Based on this and the availability of the Cobb TCM software one would think we can get old and new GTRs launcing relatively similarly and giving identical acceleration figures.
Martin
Now I can stop thinking about wasting a pile of money on the new model.
My 2010 already has your full Ti Exhaust system and a bunch of other stuff.
Sounds to me like some of those 08, 09 & 10 GTR's that have popped up on the car sales website to upgrade, would be better off giving you a call and going to their local Willall/Cobb tuner and get updated mechanically for a truck load less $ than buying the new model.
Your detailed data makes me feel a whole lot better about my decision to keep my car and continue to upgrade it.
I also just ordered your splitter through Mercury and I think your turbo upgrade kit etc, is on the cards in the near future?
Kymbo
Thanks Kymbo :)
From our analysis the reason that the 2011 is quicker in magazine tests is not only its improved transmission software, but the ease with which you can put it into Launch Control mode. Many journos struggled getting their head around LC2 and simply bogged the car against the brake thinking it was in Launch mode...when in fact it wasnt. LC4 makes it easy for scribblers to actually get it right for once - hence the car road tests as a missile :)
so martin , according to the dyno there is about 10 ish kw difference . But carsales has this in their reviews -
"Despite a significant increase in output, now 390kW/612Nm against the predecessor's 357kW/588Nm, the GT-R is so tactile in delivering its mother-load that one would really need to be insensitive to such astounding figures to make a schemozzle of proceedings."
that's at 33kw difference , one car is either over stating or the other car is under stating.
they're quoting engine power. and again not sure if what they are quoting is 100% accurate.
thanks for sharing martin. 09s certainly are rich and the 11 is nearly a full point leaning right through the map. I guess the leaner tune, more midrange boost accounts for the power difference really. the 11 really has a nice hit of boost in the midrange which would certainly make it feel a hell of a lot faster too.
ultimate results are not surprising. they have the same hardware and once tuned the same 'software' so getting the same output is no surprise. again, thanks for posting.
Bit of a noob here and have a question regarding the launch control? Hope someone can set my mind at ease. Looking at getting a R35 but not sure on 09/10 vs MY11 - Was leaving toward the 11 due to the launch control being covered under warranty and not so hard on the transmission.
1) So is there a concern with transmission issues on a used 09/10 with launch control - does it void the warranty?
2) Can the software changes for launch control applied to MY11 be applied to MY09/10's
Thanks
LC was discussed at length a while back here
cliff notes;
- 09 ADM build has LC1, but need to turn VDC-OFF, hence no warranty
-10 ADM build has LC2, but can be used with VDC-R and few hundred rpm lower, hence warranty
- 11 ADM build has LC3, but can be used with VDC-R with similar rev limit to 09 ADM, hence warranty
of course that warranty is all dependant on you leaving the car 100% stock, or lucking it up with a mod friendly dealer when something goes boom
if you wish to improve LC even further, cobb have that covered
http://cobbtuning.co...oducts/?id=5676
- ENHANCED LAUNCH CONTROL:Updates TCM to Nissan LC2 launch control logic with two user selectable launch control modes! Level 1 sets launch control revs to 3,300rpm (300 more than stock LC2) with more aggressive clutch engagement and throttle curve. Level 2 raises launch control revs to 3,700 rpm with the same clutch and throttle characteristics as Level 1.
imo LC is fun the first couple of times as a novelty when you first get the car, but as you begin to modifty the car, i dont find myself using it anymore or necessary to go quick off the line - save your tranny/drivetrain the stress and reduce the need for any repair bills
Edited by domino_z
Correct - it was only the few 08JDM imports that came in that had the LC1.
All Oz delivered cars had at least LC2 that you could launch without the VDC being off. The only warranty concerns were if you switched the VDC off - but you could launch all you liked.
sorry Hazey i gotz those cliff notes wrong
either way, dont get too caught up in the warranty of using LC
if you have any shred of adrenaline or motoring enthusiasm in you, you wont keep this car stock with that pitiful electronic whine of an oem exhaust and limited by design 'apple iGTR'1 factory power output
1Fungoolie - pure geniusism
Its not "just" the power upgrade that I like about the 2011 model.
The interior is nicer, the suspension is smoother, the wheels look awesome,
and then there is the new colour.
Nothing wrong with the 09/10 models - never will be.
Just good to see the little tweaks have made it a better overall car than the previous one.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
    • It always seems the uglier an animal is the more is costs
