hey guys,
I have a 93' NA 33 - and gears seems to be fairly smooth, except when for example coming up to a light/round about - i go to shift down into first and it wont go in...
If i try and force it it crunches BAD - so i need to hold clutch in while rolling forward with a slight pressure on it then it will go in....
Problem with gearbox? Oil change help...i brought it a month ago and haven't looked at oil level/type in there...
idea's?
https://www.sau.com.au/forums/topic/37084-gearbox-crunches/
hey guys,
where did you learn to drive skyline yet alone a CAR!!!
WOOOT into 1st?:slap:
I am not even bother to expalin....
https://www.sau.com.au/forums/topic/37084-gearbox-crunches/#findComment-742183
no need to be rude gluey
life aint fairy tails... Its a BITCH so get used to it!! :(
on the seriouse side, I dont think I was rude on that comments, think about it you doing 20kmph around corner/round about then you get compression lock cuz you put into 1st gear then you take out pedespraints or pole or end up gutter somewhere.... well it can happen wet/oil slick roads (especially roundabouts)
so why is worng to tell youngun to how to properly drive. and if its RUDE... so be it.
https://www.sau.com.au/forums/topic/37084-gearbox-crunches/#findComment-742476
yeah dude dont shift into first, stay in second unless youve completely stopped.
it wont do any harm staying in second, even if you roll to 0km/h. just clutch in if you feel the engine shudder (stall point). you can even take off from 0km/h in second gear and its fine
if your really keen and wanna challenge you can even try taking off in 3rd
first should only be used when taking off and thats it, never go into whilst moving
its a struggle :(
https://www.sau.com.au/forums/topic/37084-gearbox-crunches/#findComment-742517
First Rule: Unless you've come to a complete stop, don't ever put it back into 1st whilst still moving. You *can* put it into 1st when at a reaaaaaaaaaly slow crawl but that's not even necessary... 2nd will do fine even from there.
And even if you're "< 10km/h", it's obviously still too fast, because it'll do exactly what you're describing.
"i go to shift down into first and it wont go in... If i try and force it it crunches BAD"
Second Rule: NEVER FORCE YOUR GEARBOX. It's telling you "NO!" for a reason. Great way to fcuk up your gearbox mate.
Third rule: Read "First Rule" again.
https://www.sau.com.au/forums/topic/37084-gearbox-crunches/#findComment-742583
I can never get my box into 1st gear >20kmh unless I force it, or I double clutch. At first I thought my box was rooted, but I find that almost any car with any decent ks on it behaves exactly the same! A good oil change with Castrol VMX 80 will help things.
https://www.sau.com.au/forums/topic/37084-gearbox-crunches/#findComment-742755
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
