im interested in buying one of those nismo, 320kph 11,000rpm clusters but im not sure whether or not it will work in my car or not. is it a straight plug and play, or do i need to rewire it. and ive
also got a series two with A-lsd, slip, ABS and hicas lights, would these still light up on them or not. even if they dont will it impede on the system or will it work perfectly fine?
any help would be great.
https://www.sau.com.au/forums/topic/371053-nismo-clusters/
haha i bet. but their even dearer.lol but i still want one. unfortunatly i just bought another engine cause mines stuffed, u got any idea where the best place is to order a engine rebuild kit would be for a series 2 rb25det? and a head gasket to suit a bored 25 to 27?
https://www.sau.com.au/forums/topic/371053-nismo-clusters/#findComment-5916486
It only goes upto 179km/h
No it goes much higher then that
Because the R33's have electronic speedos rather then cable driven, the speed is sensed from the gearbox output shaft and converted in to an electronic signal. I'm pretty sure that both GTS-t and GTR both have the same diff ratio, so the speed sensed from the output shaft would be transmitted as the same value to the speedo from both gearboxes.
The only thing that would make them different would be a different diff ratio. I'm pretty sure they both share the same ratio, but happy to be corrected
https://www.sau.com.au/forums/topic/371053-nismo-clusters/#findComment-5919640
really pete!!! Thats great then!!! Gotta love Nismo
Please PM me a price, im after a white faced one for R33
hey can i also get a price for that same dash? they are nice upgrade :ninja:
Edited by SliverS2
https://www.sau.com.au/forums/topic/371053-nismo-clusters/#findComment-5919681
I could only ever get mine to go upto 179kp/h on my R32 :/
https://www.sau.com.au/forums/topic/371053-nismo-clusters/#findComment-5920637
  • 1 month later...
all stock japans cars have limiters built in by the computer this is what they call the genltemens agreement. the R35 GTR has a sat navi so that if your on a race track it unlocks the full power of the GTR.
https://www.sau.com.au/forums/topic/371053-nismo-clusters/#findComment-5988302
They mean the actual number represented on the Power FC hand controller. Every one knows that Jap cars are speed limited to 180km/h. It had nothing to do with a "gentlemans agreement", it was simply that you only needed to build the car to be able to go to a maximum of 180km/h safely. The "gentlemens agreement" was referred to manufacturers in the 90's limiting power output to 206kw (even though they didn't).
And the R35 GTR doesn't unlock the full power when you go on a race track, it simply removes the speed limiter.
https://www.sau.com.au/forums/topic/371053-nismo-clusters/#findComment-5988392
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
