update found out my head is ported and fitted with over sized valves.
indy white 1600cc injectors + fuel rail
Jun oil pummp
Adaptronic 440
Jun plennum + 90mm TB
Oil cooler fitted
Kelford 260deg cams
+ E85
Aiming for 550rwhp
  • Replies 99
thanks it might be changed at a later date sits way to low to the ground as in 3cm lol..
Toldya so, nyanya :nyaanyaa:
Ported with o/s valves ya say, hmmmmm... we need to get some cams in that sucker. :thumbsup:
thank you santa for my new wide band o2 sensor and adaptronic ecu. Also had my cooler piping made up and started my custom timing cover..
Edited by johnbarry88
cool, Im interested to see how your custom timing belt cover goes, I need to do something like this as well since Im using the rb26 cam and belt covers but dont want to just cut a hole for the vct pulley...
are both covers alloy??? I guess they must be
nah the 25 is steel and the 26 is alloy, ill be using an epoxy to join the 2 should have it finished this week :) think ill paint my coil pack cover and timing cover in harliquin.
yay car starts and runs a little rich 10.2 lol:D will do a little street tune on pump fuel so I can give it a drive then when we get back from Europe it'll get a full tune on e85 :D. Also got some work meisters for it :D
lol yeah mate the next 2 weeks are going to be full on. On another note, found out that the guy who sold me the car was indeed telling me the truth.
found:
full ported head intake and exhaust
Over size valves on both sides
10mm exhaust studs
Spool rods arp bolts
JE pistons
bottom end arp stud kit
head stud kit
lightened flywheel
gt35r setup is now sold and new setup is underway :)
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
