Lots of mis-information there ^^^^
In regards to...?
BTW to correct my last post, Power FC D-Jetro has a lot more tuning capabilities so don't get me wrong. In terms of tuning it's a big deal but in terms of power difference then there wouldn't be a big difference between a NIStune and PFC.
Most of it came from NS, so...... :glare:
This is true but how well it's paid off? We'll see how the flames go.
I would have thought that if the Nistune handles the Z32 AFM's and aftermarket injectors etc that it would be the better option. That is if it can control the idle better than a PFC and peg back the timing it it is knocking. If it doesn't then it is going to be pretty similar as far as I can tell. I haven't read up much on the Nistune as I have a PFC which is why I'm not too sure about it's exact pros and cons. If if is the change in AFM that causes the idle issues with PFC then maybe Nistune is in the same boat depending on what it can adjust for idle?
Is there a better option for Nistuning an R33 GTST, ie any pros and cons of Z32 or R32 ECU's?
Z32 can control the VCT and it has something else that it can control better, I can't remember but pete from nistune was telling me, might have been something with the knock sensors I can't remember.
But you can easily control the VCT via an MSD window switch or an eboost street (with built in window switch). There is plenty of discussion on the nistune forums and on here regarding the differences if you do a search though. :)
Nistune can be set up to idle really well with most changes, but as with all such things, spastically large injectors or massive AFM capacity mean that you're working at the very bottom end of the scale (pulse width or AFM voltage) when idling, so you'll still end up with fluffy behaviour once you go past a certain point. It is the factory ECU in all respects except that you can change the maps and the various other values. So the code that makes it run remains the same - the same smarts. I suppose there are probably a number of places where we push the tuning out past where the ECU designers expected it to operate and so the code might not be smart enough - but it still works pretty well even when pushed. The main place where Nistune falls down is when you want to do things that you can do with aftermarket ECUs like run aux outputs and ECU based boost control.
The other place where Nistune suffers is that the factory ECU sometimes sucks at reliably detecting knock and switching to the knock maps. Some will work fine. Some will change to the knock maps when there's no real knock at all, and others won't change when it's pinging its tits off. Mine was wrongly convinced it was knocking, so we ended up having to make the knock maps the same as the main map to keep the tuning as we wanted it. Some years later, it's still running that way and it's perfectly fine.
If you use an R32 ECU to run an RB25, the main thing is you need to use an external control box to switch the VCT at the right points. If you use a Z32 ECU, it can do the VCT already and you just have to rewire the outputs for the different firing order. They are otherwise all almost the same ECU. The tunability and so on is all pretty much exactly the same. The Z32 is probably the easier option overall.
There may be other points for an aganist, but that's pretty much the core of it.
  • Like 1
Yeah do not trust the knock sensors, I had audible knocking that was not picked up with them. From talking to pete he is in the mind that due to overwhelming engine noise above ~5k the knock sensors increase the threshold massively and basically ignore knock, hence if peak torque is above 5k then it will probably ignore knock, where as with the stock turbo peak torque (and hence where knock usually occurs) is around 4k
Edited by Rolls
I bought into Nistune since I wanted to have data logging and the ability to map
via a connected PC with all the data presented nicely.
I do map myself, but if you're not into that kind of stuff you might consider the PFC.
Knock detection display is still under development with Nistune, so if you want some flashing lights
at knock events you better go for the PFC.
Also the Z32 ECU is not directly a plug in ..
The ECU printed circuit board has to be slightly changed.
So for a tuner the PFC is probably the easier option (as for installation)
You don't have to rewire the firing order ...
That was a misconception and has been corrected in the Nistune documentation.
Edited by Torques
I'm a tuner, I do powerfcs, Vipec, and Link.
Played with a nistune, it is by far the best on a budget, and just as capable as the powerfc, if not more capable.
The others are for higher performance applications.
Correct.
A few things like fuel temp sensor needs to be changed inside the z32 ecu.
Ill be doing a z32ecu to rb25 on my new 32gtst drifter.
Just need to find an ecu for cheap.
You can get them from the states pretty cheap. I paid ~US$50 + Postage.
have you got a link at all??
That was second hand (of course) and was through eBay and was 18 months ago so no link but i'll have a look now. There were a number at that price back then.
EDIT!! Here's one close to that price,
http://www.ebay.com.au/itm/1990-NISSAN-300ZX-ECU-Engine-Computer-A18-A68-MB1-/170669745331?pt=Motors_Car_Truck_Parts_Accessories&hash=item27bcb5a4b3
Edited by D_Stirls
What are some stand out features of the D-Jetro that make it better than a nistune for tuning? and have you personally used both to determine these differences?
By what I've read, the MAP sensor doesn't rely on air flow but it functions via air pressure which can lead to better response and power output once tuned correctly. D-Jetro also has launch control, fuel / ignition cut, anti-lag, NOS, etc which are some features you may or may not use.
I was going to take this path, but I wasn't aiming for high power so based on my findings and having a NIStune setup, the NIStune is the best bang for buck. Hit up a few searches and this will also confirm what I've just typed.
Power FC is 20 x 20 and NIStune is a 16 x 16 resolution so if it's a high RPM revving monster then PFC should be considered.
I remember reading that NIStune is tuned cell by cell at 500 RPM intervals, think it was ns.com though so take that with a grain of salt.
Even though the PFC has more cells to adjust the standard ECU calculates/interpolates better between them. I think the new HPI covered this subject come to think of it. The standard ECU takes TPS into the load calculation. Not sure if all PFC's do that? So if you got your cells as smooth as the PFC with the Nistune then is should calculate the load points better under dynamic conditions. In saying that I don't know if you can adjust the load points, ie if you can't what happens once you go above the standard redline?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
