I'm looking at importing an R32 early next year before the import regulations change, so at the moment i'm doing as much research as I can into exactly what I should get. I'm still debating whether or not it's worth paying the extra amount to get a GTS4 vs a GTST.... what do you guys think? What concerns me is that if I go for a GTS4 I will have less overall vehicles available to make my choice from. Also, fuel consumption will be worse, and I'll lose more power thru the drive train, which I can't really afford on a 2.0 l engine. Would it still be worthwhile or should I stick with a GTST and get a nice one?
Any other advice or suggestions as to what to get would be gratefully accepted.
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/
ionos, the 4wd system (ATTESA) is computer controlled. the car is in full rwd mode unless it is putting power to the front wheels, so dont really worry about the fuel consumption. Control the fuel consumption with your right foot.
with the gts4 you can just pull a fuse out and go rwd only (as ABU53 / LA LA does...often) and i have seen ATTESA save him and the car from, well, doom. so it can be a pretty handy thing.
gts4 is heavier, if you want to get good throttle control and like rwd, go for the gtst, if you want the different (more advanced?) driving experience ATTESA can give, go for that. if the rear starts to go you can still turn in, as power will be fed to them. drive both.
good luck big fella.
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/#findComment-60843
if you can get the GTS4 i would go for that. Just like a baby GTR.
Also, if you are importing, I would be careful that plates dont run out. I have heard rumours that there are less than 25 r32 plates left in victoria.. as I said , rumours tho, so i wouldnt know.
go here for a bit more info re the new scheme: http://www.prestigemotorsport.com.au/indupdates.html
dave
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/#findComment-60886
I may be biased but I would definitly recommend the GTST.
They are lighter and you have a greatly balanced car.
Just keep in mind that, YES, you do get better launches with the GTS4 but I am sure that the GTST would catch and pass it down a quarter.. also, there is more to life than quarter mile runs..
I think that the RWD/front engine design is still the best and has the best balance.
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/#findComment-61431
Maybe i too am biased, but life is not all about launching the car.. once you're off the line the GTSt will kill the GTS4... big weight difference. Less stress on brakes etc with the weight of the GTSt too, tighter around the twisties too i'd wager.
For the right price, you could have my R32 GTSt :D
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/#findComment-61471
Thanks for the advise guys! I think a gtst would be the way to go, my logic is for the extra amount that a gts4 would cost, I could get a nice gtst with a few mods, that would go just as hard. I'm driving a front wheel drive at the moment and i HATE it, just can't wait to drive a powerful rwd car again.
Now I just hope that when it comes time for me to import, there are still plates left. :D
Morgs, what do you have, and how much? :) I wouldn't mind paying a bit extra for a local sale, but all the private sales i've seen in SA want $16000 + which is an absolute joke for a r32 (in stock form).
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/#findComment-61474
The GTS4 comes standard with 4 spot front brakes (well at least mine did) and I've driven both, owned a GTS4 for 3 years and driven various GTSt's over the time. In the dry, on the twisties, the GTSt's are slightly better. They are also slightly better on rolling start drags or overtaking due to less weight. For every other situation, the GTS4 absolutely OWNES the GTSt. Wet weather is so much better with the '4 as is any non tractable surface. I remember towing a bogged 60 series Landbruiser with my GTS4 :) I had to get him 10 meters and my car did it with style :)
Now the brakes, oh god were the 4 piston calipers with ABS bloody good. Oh yeah, all GTS4's come with ABS standard, thats very well worth considering. Problem is, if you reef the handbrake on mid corner, the ABS unlocks the back wheels and 4WD engages trying to deliver identical torque to all wheels :D
One thing I learned with the GTS4 is how to drift and stay safe. With the GTSt's it's easy to go too far and spin out, the GTS4 pulls power to the front wheels after you start drifting and you get such a wonderful sensation of drifting and knowing there's so much more room before you get to the limit. I had adjustable KYB suspension in my car and it handled brilliantly, better than most GTSt's but the GTS4 is front heavy and tends to understeer much more than the GTSt's if you aren't gently powering through the corner.
Another great memory I have of the GTS4 is tying both towing hooks at the back of the car to a tree, putting some oil under all 4 tyres, in first, smoking them all up, almost redlining at 60km/h I pushed the cruise control button, opened the door, stepped out, took a photo of the car with all 4 smoking up, jumped back in and disabled cruise control :)
I ended up selling the car, pretty much in perfect condition with 103,000km on it for $9500
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/#findComment-61675
Argh the options. Slip mentioned that the 4wd was only engaged when the rear wheels lost traction... does that mean that you will not lower power thru the drive shaft when it is not engaged, or will you still lose more power like all 4wd's?
Also, how much heavier is the GTS4? I'm a big guy :D, and with me and the girlfriend in the car, it's gonna be a lot of extra weight on that poor 2.0 l motor.
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/#findComment-61704
Originally posted by Bozz
Another great memory I have of the GTS4 is tying both towing hooks at the back of the car to a tree, putting some oil under all 4 tyres, in first, smoking them all up, almost redlining at 60km/h I pushed the cruise control button, opened the door, stepped out, took a photo of the car with all 4 smoking up, jumped back in and disabled cruise control :D
Baaaahahahahahahahahahahaah
Bozz - you are officially now a legend. I love your work..
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/#findComment-61732
yep, u shouldnt lose power as bascially it functions like a rwd until the rear wheels start to lose traction.
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/#findComment-61750
Regarding the Brakes on the GTS4..
The GTST type M also comes with 4 pot calipers and ABS.
Dude..
Read these 2 articles, then decide for yourself..
GTS4
GTST
Then decide for yourself.
Every person on here is going to say get this or get that because that's what they have.. this includes me.
But read up on both machines and choose for yourself after driving both.
IF you can find a GTS4...
It's pretty hard to come by one of those and when you consider that for the price that people are asking for a 90 model GTS4, you could get like a 94 R33, it's hard to go past the R32 GTST (my opinion once again..)
Good luck in your search..
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/#findComment-61865
And that's in Japan..
So finding one in Aus let alone a good one, is next to impossible.
As for GTST's there are always some for sale..
I've seen them as low as $13K (stock and pretty average)
Up to as high as (I personally think too much) $22K for one that has the GTR body bits and good engine mods and looks and so on.
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/#findComment-61936
Morgs, what do you have, and how much? :D I wouldn't mind paying a bit extra for a local sale, but all the private sales i've seen in SA want $16000 + which is an absolute joke for a r32 (in stock form).
Its a gunmetal grey R32 GTSt, exhaust, filter, suspension, the usual mods, and pricewise looking at about $16K. Put it in the TP for $17K but mostly time wasters from there.
https://www.sau.com.au/forums/topic/3716-r32-gtst-vs-gts4/#findComment-61949
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
