I would also like some opinions on this same kit as I am just about to buy one! Can't decide between this or the Coolingmist GS PRO.
They both have plusses and minuses, but the Snow Performance controller just looks so much better :P
Is anyone else using one?
I've got my settings at 30-65 IDC and 8-14 psi and was wondering what others were using?
Also has anyone tried passing emissions with a WMI kit fitted?
I would imagine that it would actually give you a better result with an emissions test??
mine is an older kit but its set to start at 8 and flat out at 20. it was also fully operational when i passed the nsw emissions testing.
you will likely find the car never sees 8 Psi while they are testing.
Guys what size tanks are you running and how long do they last?
I'm about to order a stage 3 kit and you can get a option for a bigger tank just dunno wether it's necessary.
Sorry for the hijack.
i am running the large snow performance tank, 9.5L capacity.
How long a tank lasts? months, too long to remember fill dates.
I have the 2.8 Ltre tank and for normal highway miles I can do 2000km on a long weekend and am lucky to use 1/2 a litre.
I am usually sitting on 100-120km/h with overtaking and accelerating etc, the normal stuff. So unless you are racing all the time the small tank is heaps. I didn't need 10 litres sloshing around when I couldn't use it.
Have a look at how I mounted mine in the ash tray recess:
http://www.skylinesaustralia.com/forums/topic/306109-my-wmi-install/
No cutting or anything, pretty much a straight fit with some small brackets to hold it there.
Pretty good read which covers installation and results.
It's for a BMW but still worth looking over
http://www.e90post.c...ad.php?t=297336
the last snow WMI kit we had through was on a late model BMW M5.... 304rwkw without 348rwkw with it turned on and setup via injector duty (no ecu tune changes) cant complain.
Trent would it still be considered "unsafe" on an unopened engine (25) over 300+ kw using WMI? From my limited understanding it has similar effect in regards to knock and temps etc to e85.
I have just installed a 2835 pro s which as we all know will net me around 280 but I'm a little worried about pushing much more out of the stock bottom end.
What sort of gains would you expect on an rb25 with a ~250kw turbo that has maxed its capabilities out (eg hot intake air), would it let you run much more ignition timing to make a difference?
Rolls I'd think that you would get an extra 30rwkw out of it.
On the forums they say that 93 octane with 50/50 wmi is 116 octane. Its not what I say, but is quoted on the forums again and again.
So what would your motor do with a cooler combustion chamber and 116 octane fuel?
I remember seeing a really good graphical plot on the differences between no wmi, 50/50 wmi and 100% meth. I'll see if I can find it, but it was a while ago.
In the meantime is you look at:
http://www.snowperformance.net/forum/
and
http://www.aquamist.co.uk/vbulletin/index.php
you will get a good idea of the benefits. There are others as well, but these pretty much cover it all.
Do you get the same benefits combining water/meth with E85 as you do with 98 octane? Or is there sort of an octane limit where the increased knock resistance doesn't help you extract any more power?
Thanks for the answers anyway, I might look into it in the future.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
