No it's not at all. The only reason everything thinks that is because no one trains legs as much as they should.
Most people are benching around 100kg, then struggle to squat 100kg. That is DISGUSTING!
If people actually trained like they should, 120 atg squats would still be warming up.
Oh I forgot we were all going to the gym for the same reasons as you...carry on...
  • Replies 158
Come on brah.
He's right, ppl that can bench 100kg but can't squat 100kg is just sad.
Sure we all don't want big legs, but people who are top heavy with pencil legs look pretty fugly.
So you obviously didnt read anything i said. Doesn't matter what you train for, train everything equally.
What do I go to the gym for if your so clever then?
I'm no powerlifter dude.
I lift weights, I do lots of circuits(bodyweight and weight), I do lots of long distance running and sprint work, I swim alot.
I train to be fit and strong at everything. Is that so much different to everyone else???
Come on brah.
I never said people who are top heavy don't look silly. You do 20 reps of 120kg dumbell squats and you aren't going to end up with pencil legs. And what if your squats are done in conjunction with a heavy 45 degree leg press? Barbell squats are good, very good, but they aren't the be all and end all of leg exercise.
Train everything equally? So a competitive long distance runner should be hitting the gym with a ton of bench press, building a nice strong upper body instead of minimising weight up top? You really have no idea. Yes, it is so much different to everyone else. If you can't see that everyone has different goals and ways to go about achieving them, then you're something of a narrow minded tool, living up to your reputation in previous threads.
Yeah but that's more than 100kgs lol.
My point was, if your squat isn't higher than your bench, something is wrong, the legs should be MUCH stronger than the functional muscles required to bench.
Well as I said, my gymnasium has 60kg dumbells...I don't know where the 100kg figure came from.
I agree, legs should be stronger than the muscles used during bench press. Not everything is about weight though...consider that you're doing twice as many reps as on bench, with 20 more kg. Legs have been shown to respond better to high reps than the rest of the muscle groups in the body, which is fine...it creates good endurance and in the end it's just another way to build up your legs. More than one way to **** a ****.
Wow you guys are all doing over 100kg's and I'm only doing 50kg LOL, ahh well got to start somewhere :D.
How do you guys get a barbell above your head? I workout at home so I don't have a high rack to put it on
try front squats, easier to get the bar there than on your back
your going to struggle to do the really heavy squatting at home with no rack but there are heaps of exercises to do with lighter weight... search squatting on youtube and you'll find lots of variations... dumbell squats as birds suggested, good when you have no spotter as you can just drop them if it gets a bit heavy...
split squats
overhead squats
one legged squats (good for low weight and core stability)
are you guys using straps to deadlift? I've never tried a 1rm on the deadlift but I do about 140kg for 6-8 no straps... I've also seen people put the bar down between each rep, might try this as usually my hands get tired before anything else
Brilliant! Should have mentioned this one before - another way to extend the lower weight of the dumbell squat. It will also be safer to do this exercise with dumbells than a bar.
No straps, no belt, just chalk.
I don't let the bar physically rest, it just 'clinks' the ground.
Who said no one has different goals. I was basing my comment around general people that go the the gym and train to be big, strong and/or fit, ie 99% of the people on this forum.
I said train everything equally, and this is obviously related to your goal. A competetive runner will train every muscle he needs to run equally, same as any other athlete out there. If your goal is to get a big chest and thats it, then yes, train your chest, and train every muscle used to make your chest big equally. If you want to be all around strong and bit, then work everything equally, which is in reference to my other post.
You know what i mean, your just trying to nitpick for some reason, we are both on the same side here.
I know your a pt and all, but before you even started thinking about doing it it was running my own pt business for a few years, then went into strength and conditioning coaching for various athletes out there, which i did full time. I also studied nutrition and naturopathy, and worked full time in that also. I now work with some of the fittest and strongest guys going around. I also competed in olympic lifting and powerlifting a long time ago now...
So if you think I'm narrow minded think again.
I use straps when im doing rack pulls, as im pulling more weight than i can deadlift. But with deadlift i'll just use chalk.
And a deadlift should be down stopping at each rep.
You'll gain more explosiveness off the floor if you lift it from a dead stop each time (hence the name deadlift).
I used to bounce my reps but since i changed a years ago now it did make a big difference when you go for 1rms.
No offense but under 100kg isn't a heavy squat, 10 reps would be easy. At weights like 150, 160 etc its a big difference. Mine was on a 5x5 strength program where if I got a 6th rep out, I'd increase the weight. So those 5 reps are basically 5 reps with nothing left in the tank after each set.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
