Hey guys, My names Racqel.
I am looking for someone to kindly let me use their car (they can obviously drive it) for my formal, which is in November (2011).
It will be driven around the Wollongong area, to the photos, then to the formal, that is all.
I am willing to pay 100-200 dollars, for an hour.
I am looking for a clean silver GTR (R35)
or a 34 gtr.... if it's nice enough :P
please get back to me ASAP!
"I am willing to pay 100-200 for an hour"
Is the above said paragraph separate from the rest of the thread? If so, may we gentlemen relay what other services 'er extras we can offer for that price and within that time frame?
Ok, here's a constructive comment for a change;
There's very little R35's around in the entire country, then again the section of those that is silver is smaller again. So the chances are pretty small.
On top of that, the chances are that if one was available and in Silver, they'd live in Sydney. So out of the $200 on offer, they'd be making $150 after expenses...
....but the biggest issue? Someone with an R35, which is worth over 100k, probably has plans that dont involve formal runs.
Sorry to be blunt.
You're better off to find a nice R34 GTR (and there's certainly a few of them on here) and make the offer to the owner. If you find one with a big exhaust and cams it will sound downright angry and lets face it, you want it to stand out in the crowd and have a better car than your friends - the sound of a tuned RB26 at idle with cams will sound so much better than the usual formal cars like H2 hummers, S class Merc's etc, believe me that will grab attention.
Here's something I took my mates sister in to her formal a few years ago, this thing sounds great and there wasn't a single person in that line not looking at it. Sounded a million times better than the other cars there on the day;
End of the day, you'll have better luck finding an R34 GTR. Good luck with it.
Too good Terry.. too good :rofl2: :rofl2:
beer boss- im sure there must be a few 35's willing to do it.
i fellow forum member was going to drop me off to the formal last year. but group of lads + pre drinks, i thought maybe next time lol
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
