Hi there guys,
I have a little issue with my GTR, basically it loses power while driving then seems to come back in a few seconds.
The first time it happened i was driving completely normally, it was starting to build boost @3200rpm or so, the car lost all power and rpm dropped to just under 1000rpm. I immediately stopped the car and turned it off, when i restarted it one minute later it drove fine but happened again 2km later, just before i got home.
So far my troubleshooting yielded without success:
-Bad battery; as i hardly drive it the battery was dying so i changed it to a new high cca battery
-cleaned elec connection points for CAS
-cleaned AFM
Still to come/ideas
-Ordered new spark plugs and splitfire coils
-Bad CAS?
Ruled out:
-Loose cooler pipe as on WOT, boost holds strong.
-No backfires or running rich (no black puffs of smoke)
-No knocks (under 20)
Basically these intermittent faults are the worst cos the car seems fine, starts fine, drives fine and power feels the same so before i must take it to the professionals im hoping someone can maybe help; maybe had the same issue before?
I would be very appreciative of any help or advice given as i know this forum is one of the best when it comes to helping out fellow skyline/car enthusiasts.
-Johnny
https://www.sau.com.au/forums/topic/372332-r34-gtr-issue/
You guys are rockstars, it was some loose wires/connection of the AFM.
started the car just now, jiggled the airbox and the car stalled.
now ive just gotta figure out how to fix the plug. Can anyone shed some light on how to rewire the plugs or replace them all together? as i dont want this to happen again.
Can I buy new ones or does it require cutting them off and resoldering them back? I do wish to buy new plugs just for piece of mind or are they hardwired into the entire loom?
Again, thanks so much to you all.
-Johnny
https://www.sau.com.au/forums/topic/372332-r34-gtr-issue/#findComment-5939108
Just note - it may not be the connector/wiring at all. Just as all three guys above have said, the fault is common and it is inside the AFM. Dry solder joints that don't conduct properly all the time. Subject to vibration. The AFM can be opened up and repaired (which is fiddly) or you can just swaptronics it.
https://www.sau.com.au/forums/topic/372332-r34-gtr-issue/#findComment-5939244
Yep it's not the plug, its the gizzards of the AFM.
Time for Nismo upgrade, dont waste time with 2nd hand AFMs. It'll just keep happening.
People have had some success with repairing them, but sometimes not (as in problem comes back later)
https://www.sau.com.au/forums/topic/372332-r34-gtr-issue/#findComment-5939327
Im sure your right about the need to swap for some new AFM's and nismos would be the way to go but will need to be put on the dyno to map it.
Main thing id like to do is check which is the culprit, the plugs or the AFM's themselves
does this idea seem the way to go:
-get/borrow some standard AFMs to fit and see if that fixes the prob, if that works then i will buy the nismo units but if its just the plugs/wiring then simply fix them
I just checked the car again and it seems its either the lower AFM or plug/wire that is the one that need replacing.
what u think?
https://www.sau.com.au/forums/topic/372332-r34-gtr-issue/#findComment-5939772
In my experience it is always the lower AFM. It would make sense as its closer to the heat etc.
I highly doubt it will be the plug, your car is not old enough. If it was a R32 GTR then i'd say possible.
The wires are nice and thick/simple compared to whats inside the AFM/circuitry being the reason (if you'd seen one apart, you'll know what i mean).
Just because you jiggle and it plays up, is the tell-tale sign the internals of the AFM are dead.
https://www.sau.com.au/forums/topic/372332-r34-gtr-issue/#findComment-5939799
Alright then, thanks ash. ill order some nismo's then. can i drive the car to the workshop or will the tune be completely off until i have it tuned on the dyno? maybe tow it down?
https://www.sau.com.au/forums/topic/372332-r34-gtr-issue/#findComment-5939832
I doubt it will run well enough to be driven.
I accidentally flicked my Nismos over to stock a while ago & the car ran rather poorly :D
Just fit them there, doesnt take too long
I see your point ash. My plan is now to buy a set of second hand OEM AFM's so i can actually drive the car.
As per my previous thread of my stage 2 upgrade, i have new -9 turbz and cam gears sitting around so ill either buy nismo AFM's to pop in or simply swap my power fc to a d-jetro and eliminate them all together.
Ill search on the pros/cons of these ECU's and might even consider the VIPEC; then again, after all the hype surrounding them - has it died down yet lolz.
thanks again man.
https://www.sau.com.au/forums/topic/372332-r34-gtr-issue/#findComment-5940999
UPDATE: Ive decided to buy nismo AFM's for my car, having it towed to my tuner next week but until then im looking for stock of nismo AFM's
Do any traders or members on here have/sell them and have them in-stock to buy now?
https://www.sau.com.au/forums/topic/372332-r34-gtr-issue/#findComment-5945358
I managed to find a member who has some nismos for sale which im buying and some standards from another member which im gonna buy too.
my plan now is to use the standards while i collect the last mods needed for my next mod stage and do it all at once.
Another question to anyone in the know:
I will have a set of stock AFMs where one dosent work and i know that sometimes for budget reasons, another member of the forum will need a replacment set who might be a bit tight on cash for z32s or nismos.
Can i have my current set repaired?
they currently work fine when cold but once at operating temp, they stop working; simply a wiring issue maybe? if its a cheap fix then i can fix them supply them to someone else in need.
Might be far fetched but just wanna be able to help another member as i have had plenty of advice and help myself and would like to do the same sometime.
-Johnny
https://www.sau.com.au/forums/topic/372332-r34-gtr-issue/#findComment-5948579
    • Dose will be able to confirm this more, but a 1.5 way IS a 2 way. It's just not as aggressive on one of the ramps. Changing from 2 to 1.5 I'm not sure how though.
    • No updates on the car but figured I'd share a nice outing. All the recent work paid off and I got it all together and out the shed for a car based pre-wedding celebration for a good mate of mine. Pretty casual cruise through the hills to a pub for lunch then out for some go-karting at The Bend. Headed down to Myponga for the night We stopped in at the reservoir before heading out down to the coast for lunch via the dam  By the end of the weekend away I covered 350km and the 32 generally behaved its self. A good Shake down after being apart before the Track day in a few weeks
    • The front prop shaft from my GTR had very notchy unis, which obviously needed replacement but unfortunately uses the (usually) non-replaceable (staked) type.     A new shaft is something like $2K plus shipping from Japan.   I wouldn't even bother asking the local Nissan spares dept.     Rang Hardy Spicer but no go, which surprised me a little.     There's a place over Dandenong way that would make me a 'performance' shaft but un-necessary in my situation.   They claimed to be getting the equipment in to replace staked unis but couldn't give me a timeframe.   Anyway, long story short, found a place to do the work just 5 mins from me: https://knoxdriveshafts.com.au $420 (cash) and about a week later I have my driveshaft back.   Price includes balancing. Owner is a one man band working out of a shed in his backyard but from what I could see he's very well setup with some expensive equipment.
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
