Hi guys. listen, theres this guy in NZ that has an rb20 with a series I rb25 turbo. Hes running 13psi through an evo intercooler and is tuned with 450cc injectors and safcII. With this he's running 215rwkw. with discusion it seems this turbo should be able to support upto 19psi on the 2 litre with correct tunning, the only problem being it spools just a tad later.
that being the case, what do you think is the potential power output of this combination?
furthermore, if we were to use the series II turbo (better spoolup because of the nylon compressor wheel and slightly more efficient.) could this potentialy produce more? :bat:
thoughts please. ( especially yours sydneykid.)
https://www.sau.com.au/forums/topic/37234-series-ii-turbo-220rwkw-and-beyond/
  • Replies 82
13psi and 215rwkw.. I think your dyno's read much much higher than ours.
I've been in a R32 with a RB25 turbo, FMIC and there was no way that was making any where near 215rwkw. More like 160rwkw.
Over in SA on our Dyno Dynamic rolling roads the max a RB25 turbo has made on a RB25DET is around 210-220rwkw. THat was on 1.1bar from memory.
I wouldn't push the turbo past 17psi for mild street use.
If you are a bit of a thrasher the heat will kill the turbo.
Nylon compressor, I've heard of them exploding and throwing bits through the motor.
Do a few searches sprint.
Most I think you will make is around 190rwkw on a DD Dyno.
have you tried adjusting the spark plug gap? ( i find the spark breaks down after 10 psi) have you tried to get the mixtures closer to 12.2 to 1? Just ask R32 GT on skylinesdownunder.com.nz (I think you know him), He's got the runs on the board.
And why does everyone always make these excuses about dyno's reading differently in NZ? that's just nonsense surely.
sorry, I dont mean this as an attack on you at all, infact its not directed at anyone in particular, it's just that alot of people dont go about doing the small things to make the combustion process more efficient before progressing, and because of this I think people are not realising the real potential of there combinations.
alot of people say that rb20 turbo's are only good for 160rwkw's. Well, ATS has made 200!! Kind of makes you think hey.
besides, NZ has nothing BUT imports, so they have alot more experience than we do over here FACT, like it or leave it. (I know, I hate to give the kiwi's anything too but they do) So perhaps we ALL need to rethink our setups and spending habits.
sorry mate but the dynos must read higher.
u think us guys go to all the trouble of modifying our cars, but dont consider spark plug changes and proper ecu tunes, hahah cmon man.
who wouldnt spend thousands on modifying cars, then neglect somethin as important as sparkies which only cost a few bucks each.
Give a bit of credit.. its just not possible and there are fundemental limits of any components on any car due to simple physics.. and if it was people would have discovered it by now. Unless you somehow mananged to cryogenically freeze the turbo or something crazy, or somehow reduce the turbulance going into the compressor. Not going to happen.
I'm not saying we all do, but alot of people dont, and because of that the miss out on power they already could have had when they go and buy the next penis extension turbo thats not suited to there purpose, thats all. Now I dont want heaps of hate mail over this but we all know there are guys that ARE too lazy or ignorant (not in a bad way and not there fault.)
For instance, a mate of mine took his series 2 to a shop and staight away the tuner said his 600x280x70 PWR cooler wouldn't be any good for more than 200 kw at the flywheel (hmmm) and aparently after doing there best with the wolf 3d v4 the best they could do was 160 rwkw at 10 psi because apparently "after that the turbo fryed the air too much to make any more power". Took it home and changed the gap from there 1.1 to 0.8 and gained a shit load of power (double hmmm) we then checked the a/f ratios on the dyno sheet. It runs above 13.5 till 500rpm after the peak torque (do I have to say it?) and then promptly swung down to 10.5 to 11.0 on boost (.......). And then had the gall to ask him to pay for THAT!!! he did as he doesnt know any better. And alot of people dont realize there missing out on this power.
We later found that "Scotty at vern crawford mechanical in townsville" (the bloke who 'tuned' it) is great if you want someone to tune your carby fed V8. So good infact that he doesnt need a dyno, he does it by ear, best man around. (HMMMMMMMMMMM). there's alot of these guys out there.
Lol.
Sprint32.
You have just proven to my self your little you know and understand.
Dyno's giving different readouts is not an excuse it is a fact.
What brand dyno's do u blokes use in NZ?
Over here we use a rolling road Dyno Dynamics. Well most of us do anyway.
With around 200rwkw the R33's over hear (providing they can drive) generally run low 13's.
Sprint32,
As I understand it R32 GTS-t's only dyno so far has shown a maximum of 180rwkw, granted it was at a low level of boost, however it doesn't mean 215rwkw if the boost is turned up (that is specualtion till the dyno run is actually done). If you have different info please feel free to post up the dyno chart.
Guest INASNT
Sprint32
U can make a stock skyline read 300rwkw if u plug enough bs figures into the shootout mode data.
If u look at the compressor flow map of a stock r33 turbo it cannot produce enough air for 213rwkw. Just because u chuck big injectors etc in means nothing if the turbo cant supply the engine with enough air to make the power.
actually that 180 rwkw figure was with the standard intercooler/fuel system and an untuned safc II. He HAS since produced the higher figure. See it for yourself on skylinesdownunder.com.nz 'RB25 turbo on RB20'.
As far as I know ALL RWKW figures are produced on a rolling road dyno!! lol
INASNT: how do you know YOUR figures aren't bs? Your so ready to say his are.
As far as I know a kilowatt is a kilowatt no matter what country your in. I know all dynos read a little differently but 35rwkw. Can anyone tell me why this phenomenon would occur?
look, This will be my last post for a while as my next one will be like a novel so I'm going to make it a word document with scanned maps, charts, etc at work and then post that to show you my reasoning for this sort of power. bit dissapointed not to hear from sydneykid, still, it was good to talk.
because his turbo is rated a a certain hp off the shelf. then once it was put on the car, it mathced what it is rated to.
im sorry mate but no way on a stock ecu with only safc can a car make that sort of power. no way a stock coolered r32 makes 180rwkws, the only possible explanation is that they dyno is very high reading ''(read 20-30%) or that someone has played with the dyno printout.
Guest INASNT
Theres a thing called photoshop!! LOL
Or unless he is using one of those "Very Special Boost Controllers"!!! :)
If u want to believe that bullshit then do so, but dont try come in here trying to convince us of this bullshit when most of us have gone through the modification process step by step and have had many dyno tunes, so we know what these cars are capable of.
Yes but you all seem to be having a little trouble reading. This may be HIS result with JUST a safcII, But he DOES have other trinkets as said in the "FIRST POST", However my point is that there may be more to gain with a 'CORRECT TUNE'. I know I said it 'cause I was sitting here when I said IT.
EnricoPalazzo: I have no idea what your on about with this 'of the shelf turbo rating', you seem to missunderstand what turbo i'm talking about.
Shut down, thats dissapointing. I joined this forum because I thought we were above V8 falcadore mentality. I was actually hopeing for a thought provoking and inteligent discusion ending with some new idea's people would be willing to try. The whole idea why we bought these cars is because we're interested in doing things smarter, not harder. I've done all manner of V8's and other pushrod low tech engines and started this as something with a bit more of a chalenge. It seems to me that the biggest challenge is that people believe too much of what they hear or read. But then, who thought you'd be able to get 250rwkw out of the stock soarer turbo combination. No-one? Martin Donnan did. This was my point. push the limit and when you think you've reached it, look again. Because theres always something that affects the entire system, enabeling more to be done in an area you previously thought was maxed out.
Instead we'll do the pile of crabs in the bucket thing.
:werd:
I would say something more, but INASNT has said it for me.
RB25 turbo, on an RB20, will not make 215-220+ REALISTIC RWKW
If he wants to prove us wrong, good, tell him to hit the drag strip and bring some times home for us all to... look *cough*laugh*cough* at.
Guest INASNT
what car do u own and have u had any first hand experience with a r32/33/34 skyline??? Do u actually know anything about skylines or r u just going by what u have read somewhere else.
So how much actual power has it made at the wheels?? has it made 215 or is that what u 'think' it will make with a safc 2???
As for the zoom power figures, they dont have good 1/4 mile times to back it up.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
