I'm currently thinking about moving to Australia from the UK. I don't want to go into that here too much, but I have questions about bringing my Stagea.
Does anyone know what hoops I'll have to jump through ? Will I have to "Standardise" my motor ? If so, to what extent ? What's the procedure for registering it ? Can I run for a while on UK plates ? Insurance ? Oh and anything else that I need to know ?
It's a 1999 RS4V with a Masa body. RB25DET Neo. Induction kit, exhaust, steel internal turbo, FMIC, bigger brakes, Tein coilovers, Gizzmo EBC, R34GTR wheels.
stageas are cheap as chips here, would probably save yourself a lot of trouble and money if you left yours there and just bought another here. Australia is pretty tight with road laws and vehicle imports
Bearing in mind, my employer will be paying transport costs, so I wouldn't have that to worry about.. So what would a car of my spec cost out there ? and am I even likely to be able to find a Masa Stagea with the mods I have ?
That's great!
Australia is tops and so are Stageas! Combining the two will bring you much happiness.:thumbsup:
I too have a black Stagea, live in Australia, and I'm incredibly happy, coincidence; I think not...
Seriously, I'd pose the question of personal imports to Iron Chef; I'm sure he'll give you the info you need.
I think the rules are quite different regarding mods on personal imports, if your mods are able to pass an engineers inspection; you should have no real issues getting registration, and if your employer is footing the bill, then that's one of the biggest hurdles taken care of.
That and I like the look of your car; so bring it over here, and find out just how much fun it is to leave a black car parked in the sun, on a 40 degree day...:whistling: Do you have leather seats?pinch.gif
Edited by Daleo
Yeah, have a chat to "Iron Chef" (Kristian) about personal imports.
Depending on which state of Australia you are moving to will depend on what/if anything has to be removed from your car.
Oh, and you may want to think about upgrading your radiator for our summers (unless you're moving to Tasmania :P)
Personally I'd buy something nice and rare and unable to import to Australia, stay in the UK for another 12 months, bring it over as a personal import, flog it off in Aus for $$$PROFIT and then deck out a Stagea over here to the same or better spec with money to spare.
But that's just me :)
just do it. ive always liked this car dean, although on the DL, id like to import something special from newera. :yes:
An M35??? :P
Edited by Jetwreck
Dean stick with what you have mate ,you have a great car then sweet ,
What's wrong with a Volvo....they have a very good PROVEN race pedigree.....T5's are blood good cars...... When put up against CAMRY wagons they win hands down.
IMO I would try to stick with you car bud....looks the goods.....and I am sure you would get any help needed from other C34 guys to get it on the road....right guys!
Edited by Jetwreck
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
