seeing tho top feed injectors are easier to get hold of and tend to be a tad cheaper is it worth going one of these top feed conversion rails for r33 or should i just stick to the side feeds
Its not cheaper if you take into consideration that you need a forward facing plenum, I found out the hard way that a top feed rail simply does not fit on the standard plenum :rolleyes: lol
Hello!
I have recently bought (via EBAY) such a kit .. (so top feed conversion)
It came with the fuel rail, spacers, nice Bosch injectors, and connector pigtails.
The whole kit was about GBP 330 and came from the USA!
The fuel rail looks alright too, but I suspect made in China. (?)
I have not fitted it yet so I can not tell if it works.
You also will need a fuel pressure regulator since the OEM one is attached to the OEM fuel rail.
In addition you need to think about a set of fuel hoses/connectors since all the metal piping will be gone when you remov ethe OEM fuel rail (from fuel pump to rail, and return line from regulator)
I can upload some pictures .. (once I'm at home again)
I am not familiar with the whole mechanics, but why would one need a different plenum to go top feed?
Any help appreciated (before I start)
(Has anyone done this before??)
Edited by Torques
Hello!
Hey mate,
Basically because the standard plenum curves back over itself, there is a height issue between the bottom of the plenum (where the injectors sit) and the top of the plenum.
So by using the forward facing plenum, it allows you to use top feed because there is no height restriction.
The injectors I had were fairly large so prehaps it MAY be possible to squeeze in there with smaller ones, but I wouldnt call it ideal lol
I went side feeds, cause its easy. Just pull the old ones out put the new ones in.
Only problem is not having any aftermarket side feed fuel rails to pretty things up
are you making over 400rwk? factory fuel rail is pretty darn good.
That said (as we find the limit of side feed injectors quickly on ethanol) the new company i develop for has a rail program i hope to implement with the short style bosch ID injectors in about 2months to fit r33 and S14 S15..
yeah the stock fuel rail just looks a bit out of place with a Greddy/Copy Manifold. Thats the main reason I want an aftermarket fuel rail. Circuit Sports make an aftermarket side feed rail but apparently it doesnt fit with the Greddy plenums.... Bit of a shame but oh well lol
There was a standard rail sold on here a little while ago, guy had it coated candy red, looked pretty good :thumbsup:
Hi!
OK .. that makes sense ..
From what I gathered my fuel rail (the new one) should plug right in.
My top-feeds one are only about 1cm longer compared to the side feeds.
We'll see .. (I will report)
Hey mate,
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
