2005 B7model A4 2.0T
Brilliant Silver
2.0L 4 Cylinder Turbo (unlike the gutless 1.8, 1.8T, 2.0 motor)
97000km
Service history log books
Automatic (Had a major service few weeks ago, cost $4500 with receipt, it is basically now a brand new gearbox!!)
**The rest B7 A4s out there on the market sure hasnt had their transmission major serviced!
Black and silver duo colour leather seats (limited)
H.I.D fog lights
New Battery
New tyres and brakes
New Spark plugs
runs 98 RON
Good condition inside and out
Car drives like new, powerful, smooth and stylish! All you need is either lower it or add a set of nice rims on it, you'll be sweet~
Will not disappoint!
New car smell!!
Looked after well!! As NEW!!
Owner bought a new car already.
Oringinally wanted $22,500 with RWC and fresh 6 months rego, but to save you money, time and my hassle, I have now dropped down to $19,999
$19,999 w/o rwc, rego
0433-350-626 inspection welcome!
Call or TXT
Edited by sky_34
plenty of B7 A4's have their gearbox's serviced. Every 60,000km. See atleast 5 a week come in for it.
Guessing multi-tronic control unit was replaced at $4500.
Will save next owner loads of cash!!
Good luck with sale.
P.S. Was cambelt replaced at 4yrs/90,000km?
Yes, exactly and apparently if you don't have them serviced before 70,000km, they will start to have problems like slipping in gears, freind's one even jammed itself and got stuck on the road!
It certainly does save the buyer loads of money! $4500!! thats exactly how much it cost me (got receipt for it too!) buyer for this A4 is pretty much buying it for $15,500 in regards to the cost of the service on the gearbox!!
cambelt was changed, even the pully was replaced! This A4 is in really good condition from inside to outside! anyone whos keen out there? cheers
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
