  • Replies 64
You need to check injector PULSE and coil spark first. If you don't have either one, then yes, CAS is most likely
Coil spark by sticking a screw driver or something similar into the coil pack and seeing if it'll spark to the block? Or any other way you recommend?
Injector pulse by pulling one out? Of is it easier to intercept the injector signal and hit it with a multimeter?
ok. pull no1 coilpack out of the cradle, put the spark plug in the bottom of it and make sure its loom is plugged in. earth the threaded section of the spark plug somehow (i rest it against a screwdriver thats sitting firmly against a clean part of the head). pull the cas out, just undo the 3 bolts and carefully remove it, leave it plugged in. turn the ignition on and slowly turn the cas counterclockwise (looking at it from the shaft side), check for spark and listen for the injectors ticking. if you get either your cas is working fine, assuming of course the drive teeth are fine.
Use a jumper lead for the spark plug, much easier. Clamp one end to the motor, and clamp the sparkplug in the other end with the sparkplug plugged into the coil and loom like you normally would.
I can't help but think it's the CAS.
Do I just take it off the base plate (ie, undo the couple of small screws) or do I need to take the base plate off as well?
Yep ubolt the three screws, unclip the wiring and then just pull it out. Mark where the bolts were roughly aligned first to be able to put it back in the same spot.
Once it is out just spin the shaft and see how it feels. Like I said. There should be no resistance what so ever. When they snap the shaft it feels like grinding against sand.
Everything really makes it sound like the CAS so I would suggest doing this first prior to anything else since it is the easiest thing to do.
used to have a vl turbo and when the airflow was on the way out, it puffed alot of fuel and black smoke out the back, very similar to what your talking about, then eventually wouldnt start at all,
have you ruled the airflow out??
I picked up another one, which I can't be certain is working, but it made no difference. Aldo, the voltages seesm close (althought I need to confirm the V when cranking - my memory may not be accurate).
Fairly sure a Skyline will start start even without an AFM signal, just goes into limp mode, so I don't think it would be that.
With stock ECU, yes but don't know about PFC.
Shit I forgot about one small thing. You may have a split or dislodged intercooler pipe.
Check for leaks. AFM swap outs will not diagnose this and it will foul the crap outta your plugs. It will also cause it to run crap and basically every other symptom you described
Should still be able to start the car with throttle open though.
Everything really is pointing to a broken CAS spindle. As the starter motor spins the engine manually during start the ECU receives no signal from the CAS so won't fire any injectors or spark plugs to initiate combustion since it doesn't know the engine is turning over.
actually i can confirm that it would start, mine does without the airflow, just wont rev up pinch.gif ( with standard computer)
Yes, until the spark plugs are fouled....which takes about 5.3 seconds....and, unplugging an AFM is different to having one plugged in with no values being read
Yeah IF he has no spark and no injector pulse, but having a blown cooler pipe or a split one or even a semi large vacuum leak near the plenum will stop if from running. Details are vague over the internet so we don't want to rule out basics until they have been thoroughly checked
I've had a good hunt around for a split in any of the intake. Haven't found anything, but it was probably an 80% look, if that makes sense. It was running at the time, which would no doubt have helped substantially.
I will try and get an injector out, double check the spark and if nothing, pull the CAS off tonight.
I'm trying to be as thorough as possible so people can refer back to this as it seems to be a common problem caused by a number of things. If I can say "these were the EXACT symptoms, this is what I checked, this is what I found, this is how I fixed it," I'm hoping it will help others.
Go to repco or similar and buy a noid light.
This little guy plugs into the injector plug(easily without removing the plenum an fuel rail) and when u crank the noid light should flash. If it doesnt then there is no injector pulse.
Do some basics, check all fuses etc, then if possible borrow a mates CAS to try.
Now the fun starts.
JDMSpares wants a piece of my arse, but has made it abundantly clear they do not wish to use lube. $180+del for a CAS - tell him he's dreaming.
Anyone got a Neo CAS they want to sell to me? The going price looks to be more around $60-$90
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
