How about any time your standard AFM maxxes out? Which is about (or a bit more than) 300 engine HP. You can go past the AFM max out point, but if you want to retain the ability to control the mapping, it's worth upgrading.
this, although its more like 300rwhp (varies from car to car obviously) than 300bhp
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950382
Thanks guys,
actually I am not sure what sticker is even on mine. might have to duck outside and have a gander.
Anyway i was aiming around the 250-280rwkw with Hyypergears ATR43 SS1.5 so i guess i will need one. Just out of interest are the the same physical specs as a stock gtst one as in would the mounting holes match up to the standard airbox. I need everything to look as much as standard as possible....
Ps: I forgot to ask, has anyone seen the aftermaket z32's on ebay (brand new)? any thoughts...
for example.......
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=110559548059&ssPageName=STRK:MEWAX:IT
Regards,
Dazza
Edited by itshimdazza
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950440
hello
ECR33 AFM is 80mm and maxes around 220rwkw ish, some can do more, some less, but they all peak 5v around this level
VG30 AFM (or Z32 we call it) is 80mm and maxes around 400rwkw ish, some can do more, some less, but they all peak 5v around this level
both are a direct swap for the physical diameter and adapters but the wiring is different
ECR33 S2 is pink label 3 wire and VG30 is orange label 4 wire (extra ground wire)
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950453
there are also Z32 (really VG30 AFM's) fake on ebay so do not BUY fake ones
a legit Z32 brand new costs $350 ball park and comes in an orange BOSCH box
look at the pics of this page for a fake Z32
http://paulr33.com/techinfo/snipit.html
also Ive never seen "green" plastic based Z32s like that EBAY url you posted, they are knock offs or fakes or copies or shitters
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950454
cheers Paul, thanks for the heads up...
I often wonder about ebay copies and I would love to know what the green maxes out on though. would be an interested experiment
has any members bought something like this "a fake" and got some real testing from it like what was on Pauls URL above with maxe rekw & voltages?
Dazza
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950500
That specific ebay one isnt a Z32...
It's a dead give away with how the ad is worded. Notice how it says "aftermarket Z32", as in - not original. No where does he say it is OEM/Genuine etc. The last line of his ad says "check other listing for genuine"
That's so he can cover his ass when you realise you've purchased a paper weight :)
His genuine ones are selling for $320 or there abouts.
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950507
that link states its an aftermarket replacement and to check his other listings for genuine stuff so theres nothing dodgy going on there.
alot of the older fake z32s worked fine in every way, they just maxxed out at much lower power levels than genuine ones.
if you end up getting one a cheap solution for the plug is to get a rb30 afm plug as they're the same.
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950517
Pfff do not be telling people that fake Z32 AFMs are any good. They are not.
We are talking about a extremely sensitive and critical component of the fuel system here... "she'll be right" doesn't cut it!
It's not just about "peak power" there are many other factors at play here not least of which is consistency & reliability
Of course if it's just for your fully sik drift car with lots of go-fast stickers on the side then go for it! :D
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5951085
agree the AFM is not something that should be mucked around with
its one of the key sensors the engine uses for engine management
why do you think it rev caps at 2500rpm as a failsafe when the AFM is mangled, failed or unplugged
cos its not safe to run with a mangled one or non-working one
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5951234
Chinese copy Z32 AFMs are an absolute pain. They don't measure anything like the genuine item and will cost more in tuning time than what its worth
Nistune Z32 AFM forums link
Declan from Garage 7 shows on his website the internal differences of the Z32 AFM copy and changes in mapping here
Garage 7 link
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5952453
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
