How about any time your standard AFM maxxes out? Which is about (or a bit more than) 300 engine HP. You can go past the AFM max out point, but if you want to retain the ability to control the mapping, it's worth upgrading.
this, although its more like 300rwhp (varies from car to car obviously) than 300bhp
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950382
Thanks guys,
actually I am not sure what sticker is even on mine. might have to duck outside and have a gander.
Anyway i was aiming around the 250-280rwkw with Hyypergears ATR43 SS1.5 so i guess i will need one. Just out of interest are the the same physical specs as a stock gtst one as in would the mounting holes match up to the standard airbox. I need everything to look as much as standard as possible....
Ps: I forgot to ask, has anyone seen the aftermaket z32's on ebay (brand new)? any thoughts...
for example.......
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=110559548059&ssPageName=STRK:MEWAX:IT
Regards,
Dazza
Edited by itshimdazza
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950440
hello
ECR33 AFM is 80mm and maxes around 220rwkw ish, some can do more, some less, but they all peak 5v around this level
VG30 AFM (or Z32 we call it) is 80mm and maxes around 400rwkw ish, some can do more, some less, but they all peak 5v around this level
both are a direct swap for the physical diameter and adapters but the wiring is different
ECR33 S2 is pink label 3 wire and VG30 is orange label 4 wire (extra ground wire)
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950453
there are also Z32 (really VG30 AFM's) fake on ebay so do not BUY fake ones
a legit Z32 brand new costs $350 ball park and comes in an orange BOSCH box
look at the pics of this page for a fake Z32
http://paulr33.com/techinfo/snipit.html
also Ive never seen "green" plastic based Z32s like that EBAY url you posted, they are knock offs or fakes or copies or shitters
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950454
cheers Paul, thanks for the heads up...
I often wonder about ebay copies and I would love to know what the green maxes out on though. would be an interested experiment
has any members bought something like this "a fake" and got some real testing from it like what was on Pauls URL above with maxe rekw & voltages?
Dazza
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950500
That specific ebay one isnt a Z32...
It's a dead give away with how the ad is worded. Notice how it says "aftermarket Z32", as in - not original. No where does he say it is OEM/Genuine etc. The last line of his ad says "check other listing for genuine"
That's so he can cover his ass when you realise you've purchased a paper weight :)
His genuine ones are selling for $320 or there abouts.
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950507
that link states its an aftermarket replacement and to check his other listings for genuine stuff so theres nothing dodgy going on there.
alot of the older fake z32s worked fine in every way, they just maxxed out at much lower power levels than genuine ones.
if you end up getting one a cheap solution for the plug is to get a rb30 afm plug as they're the same.
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5950517
Pfff do not be telling people that fake Z32 AFMs are any good. They are not.
We are talking about a extremely sensitive and critical component of the fuel system here... "she'll be right" doesn't cut it!
It's not just about "peak power" there are many other factors at play here not least of which is consistency & reliability
Of course if it's just for your fully sik drift car with lots of go-fast stickers on the side then go for it! :D
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5951085
agree the AFM is not something that should be mucked around with
its one of the key sensors the engine uses for engine management
why do you think it rev caps at 2500rpm as a failsafe when the AFM is mangled, failed or unplugged
cos its not safe to run with a mangled one or non-working one
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5951234
Chinese copy Z32 AFMs are an absolute pain. They don't measure anything like the genuine item and will cost more in tuning time than what its worth
Nistune Z32 AFM forums link
Declan from Garage 7 shows on his website the internal differences of the Z32 AFM copy and changes in mapping here
Garage 7 link
https://www.sau.com.au/forums/topic/372996-z32/#findComment-5952453
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
