Just trying to work out who would you guys/gals reccomend to perform a tune after I get a new turbo in the South East Melbourne.?
I belive that Trent (Chequered Tuning) wont be doing them anymore...........
I am nearly at the stage of doing the mods but cant if I cannot get a reputable tuner to remap my tune...
Regards,
Darren
https://www.sau.com.au/forums/topic/373025-nistune-tuning/
Trent will still be tuning, but i believe will just have limited days to do so each week.
Otherwise, Paul @ Westside Chasers would be your next best bet. But definitely try Trent first
as for mpc........... go Trent or Paul
https://www.sau.com.au/forums/topic/373025-nistune-tuning/#findComment-5950314
MPC havnt tuned my car before I'm basing my choice on mechanical work I've had done there, good to hear trent is still tuning tho because I need my car done in a couple of weeks also :)
https://www.sau.com.au/forums/topic/373025-nistune-tuning/#findComment-5950352
Nar its what Stao's from Hypergear is saying based on his GTST test turbo car.
he mentioned that with all the remaps "possibly" the r33 with a z32 ecu has bugs or something and it take longe to/if fix with Trent and he says he dosnt want to do these anymore?
I just hope he reconsiders as I am in the process of an ATR43 SS1.5, injectors etc and need it tuned soon...(weeks)
Dazza
https://www.sau.com.au/forums/topic/373025-nistune-tuning/#findComment-5950413
***************Just an update from forum from Nistune guys******************
Quote
I always get datacorruption issues on the test car
How do you know for sure its data corruption? Did you read back the maps andthey were all spiky or did the ECU stop running? These are the indicators thatsomething is corrupt, otherwise there is a different issue. I have to have achat to Trentabout this one
Quote
data in it gets changedquite so often, I'm not sure if that causes the issue.
Shouldnt cause the issue. If unsure read back the maps which were originally init and compare what was saved on your laptop after burning the tune
Quote
The Z32 ECU and nistunechip on R33GTST just didn't work probably on my cars. Which it's also thereason trentstopped doing those.
The main problem with using a Z32 ECU on an RB25DET is the knock sensors. Z32ECUs use the doughnut SR20 style knock sensors and RB25DET use the hose typeknock sensors. I suspect there is more sensitivity and your ECU is jumping toknock maps
We normally recommend disabling knock feedback during tuning for this reason.Also Nistune software will now indicate which maps it is running from at anytime. Boards dont lose their tune once a burn is performed as its stored toEEPROM.
Justa follow up. Found out that Pete did the install and was supplied with a 16 bitZ32 ECU
We officially only support (and have tested base maps) for the 8 bit models forRB25. Part numbers listed in our documents for 8 bit models should assist withfinding correct units
We have not used 16 bit models so haven't got experience with these but fromwhat Trentindicated there are issues with these ones as well as a glitch found with VEmap RPM tracing (fixed in 0.10.9 software release)
www.N I ST U N E .com
Edited by itshimdazza
https://www.sau.com.au/forums/topic/373025-nistune-tuning/#findComment-5950463
I just got an email from Trent @ Chequered and he is definately not interested in doing the Z32 ECUs in the R33 any more.
Which pisses me off big time as I purchased the bloody thing on his advice through someone that he put me in touch with :rant:
So the big question is if Trent (who was the supposed master of these things) doesn't want to touch them any longer are they just a crap solution???
I do not want to throw good money after bad and end up in a world of pain and frustration.
What now???
https://www.sau.com.au/forums/topic/373025-nistune-tuning/#findComment-5957381
We are taking dealer ship with adaptronic ecus that run on Map sensors. Cost abit more but you save from the donor ecu, and Z32 AFM assembly. so works out to be about the same . I will speak to trent on Thursday to see whats the most best option within the budget, and will post up prices, all of our customers will receive a discount on those ECUs.
You can put up your Z32 ecu and nistune chip on ebay. I'm pretty sure some one will buy that package from you.
https://www.sau.com.au/forums/topic/373025-nistune-tuning/#findComment-5957790
+1 for power fc on r33 gtst easily tuned no problems and not that expensive while you can also monitor whats happening with the controller. Just sell the it on ebay as stao said will go quick then get the power fc and take it to trent and you wont regret it.
https://www.sau.com.au/forums/topic/373025-nistune-tuning/#findComment-5958492
Yes I am well aware of the Power FC thanks however they are not cheap and I already have the Nistune ECU... which up until yesterday thought that this was a good solution (in some ways it has advantages over the PFC).
PFC is good but seems to come with it's own set bugs and issues as well so it isn't perfect (and for that kind of money I expect it to be!)
Dr Drift is still keen to tune the Z32 for me..
It sounds like maybe Trent has just had a gut full of fixing other peoples f^@k ups and mucking around with these ECUs.
Trent is running a small business and has customers lining up for his services so he is in a position to pick and choose I guess.
(hopefully I will get the facts on this matter today through another contact)
As far as I know there are plenty of happy punters running the Z32 Nistune ECU in their R33 - or am I missing something? :huh:
https://www.sau.com.au/forums/topic/373025-nistune-tuning/#findComment-5958555
  • 2 years later...
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
