In OZ I suggest a larger trans cooler fullstop.... Summer time is a killer on most elements of this car....moreso on the gearbox and plenum temps.
No harm in putting in some kind of thermostat either for winter.
  • Replies 183
Might get one of the B & M ones then, check out Jase's on the cruise and see what I think.
Keen on getting the IC sorted first so I can work out how much room there is :S
TONS!
Best thing I did was relocate the horns to the side, gives you a shedload of room to work with. I should really stop being so lazy and just take a decent photo. If I get time, I will tonight!
Jetwreck installed my shift kit yesterday arvo, while I got in the way and generally hid Allen keys for him...
When you open the box and see just what you get for your money, you'd be entitled to feel a little short-changed.
However, patience is a virtue, and it will be rewarded with a gearbox that simply provides the absolute best of all worlds! At light throttle openings; beautiful smooth but fast shifts, not harsh at all. At higher throttle openings (around 3-4000rpm) firm fast shifts with a nice squat from the rear as it picks the next gear.
At full throttle, shifting at Redline on damp roads, mine now squats down, shoves you into the seat and spins the rear wheels for a car length until the torque split throws power back to the front!
Yeaaah! That's what it should be like! This mod has just scraped off the veneer of respectability that the NM35 has, and I can now see the potential it must have with another 30% to 100% more power.
If you are tossing up whether to do this mod; DO IT! YOU WILL NOT REGRET IT!
If you are tossing up whether to do it yourself; have a good hard think, and honestly assess you mechanical ability. If you are not extremely confident in your ability; leave it for someone who is.
There are many small procedures that must be done correctly TO THE LETTER, if you get just one wrong; you could well be f##ked. If you lose one tiny detent ball, or lose a spring; you're going nowhere.
I watched Craig go through the entire process, and assisted at key points, and this is not a simple job. To be entirely confident, I'd be wanting to go through the whole thing again, with his assistance.
I estimate it would take me between 6-8 hours to do my first one; checking everything twice. It takes Craig around 4 hours.
I also used Nissan Matic-J at $69 for 5lt, rather than Nulon at $59 for 4lt. You need around 8lt, so you'll have enough left to do a transfer case flush as well.
Thanks again Craig for your efforts yesterday, I couldn't be happier, the car is f##king awesome!
Edited by Daleo
Nice Dale!
veneer of respectability - I like that!
Mine will be going in tomorrow - we'll see what changes they made in the GB with the TCU and things. I really don't need the shift kit at the moment- I find the behaviour of my gearbox to be fine. What I am pre-empting is that things will be radically different when it gets some boost in it over the next couple of months, and being on the dyno for a day I don't want the gearbox to expire.
I'd be interested to see what's the diff between the transgo kit and the kit I got. If its a huge difference I might shell out for one...$260 is farking cheap...
I can't remember what the stock transmission was like...all I know is that I never used the tiptronic mode before I had my shift kit installed...and now I use it all the time :whistling:
Just come back from my install with Jetwreck.
Can only echo everything that Dale has said above. At parts of the process my mind was boggling! There were differences in my gearbox- namely we had to lower the crossmember to allow access to a plug on the drivers side- that connects to the Transmission ECU, which is sitting in the gearbox. Difficult with the exhaust in the way.
Shifts are still sliky smooth for me on low throttle, while the gear box performs much more positively on upshifts at WOT. It doesn't have quite the same effect as Dales, but then again, I'm lacking boost! Once that changes, I'm sure it will come into its own!
All sealed up again after a bent pan rail sprung a leak.
Bit of a touch up with a hammer; all sorted. Also knocked over the transfer case fluid change.
Thanks again for the use of the hoist Craig; heaps easier than battling on the garage floor.
Beers are on me next time.
Fark this shift kit kicks arse!
Edited by Daleo
looking forward to a weeks break on this now as the next 4 kits wont be hear for a week.....I recounted....thats 7 NM35's and 1 PM35 I have done.......4 since Wednesday.
On other news guy's if you want kits I am after another 2 to add to the next buy.....to keep shipping costs down.
Well done mate; man on a mission!:thumbsup:
Get on this guys; this is my new favourite mod.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
