  • Replies 58
I have read a few threads but most realize what a waste of time it is and find better things to do like attach a big single or go to the pub..
i dont think anyones saying dont do it, I'm sure we would all love to see results no matter how bad they may be..
If you got nothing better to do then knock yourself out but while your saying it wont cost anything your talking of building a stroker 3lt, Im pretty sure that will cost something and the most power i think you would make is a laggy 500-600hp at the absolute max if the turbos dont blow up first which most people think they will.. thats alot of f**kin around for the result when you could simply buy a Big single like mafia said which is proven to make over 500hp on a stock 2.5, you could have it up and running in a weekend if your good unlike this monster of a project which will take you so long that Im betting you give up on it before it ever gets finished because you realize how much effort it takes just to be lame..Im sure over the next few months we will get excuses like my missus had a baby and I smashed the car and I dropped a turbo on my babies head blah blah blah it will never happen..
Anyway GL..I eagerly anticipate your results ;)
If it sucks it sucks. I'll only be mildly disappointed if it does. I was kind of thinking 10 to 12 psi each at about 4000 to 4500. Haha... I just asked the missus " What happens if I do this twin turbo setup and it sucks arse"? She says straight up in a no nonsense tone "Buy a bigger turbo". :thumbsup: Hey why do people think that a less stressed turbo is more likely to blow?
EDIT: No parts yet. :angry:
Edited by Room42
Ok blokes. Line up your I told ya so's. :blush: The twin setup is still going ahead but not with the stock turbo's. After consideration I've decided to use better quality turbo's. Bearing in mind that it will be on the rb25 first then swapping to a relatively stock rb25/30 (7000 rpm max) what are your suggestions for turbo choice? I'll buy new turbo's etc and as this will cost more I'd rather have it work the first time. It should be more suitable for the 25/30 than the 25. Also I have a couple of T3 flanges for the manifold so take that into consideration. Lemme have it :thanks:
It doesn't have to be twins. Just seemed like a good idea cos the stock turbo's are so cheap and I can put it together for stuff all. Also I have the head flange and 2 T3 flanges paid for and arriving soon. I could always suck it up and eat my words and "look like a cock" but like I said its not hard to sort out and I already have most of the bits on the way or at work. I dont care about being different. Read my second sentence again.
Well I have 2 turbo's in the shed. Its just a matter of putting it all together when the flanges arrive. The reason I kinda shied away from the nissan ones is cos they're so old that the chra's will be rooted.
EDIT: The money is basically spent. Only gotta sort out some intake piping.
Edited by Room42
just do it...for pride and lols if nothing else.. :thumbsup:
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
