Heya all,
Seeing as most of Australia has now become rain drenched, driving on wet roads is almost a daily event. Ive noticed in recent months my R34 loves to aquaplane at the slightest (smallest) build up of water on the road.
Last night on the freeway at 110 or a lil less the car constantly tried going sideways again in the rain (mostly higher freeway speeds it always happens but it can happen at just 60ks too)..... finally its made me ask the question;
Does anyone have any advice on how to reduce aquaplaning in a car, mebbie specific to Skylines or is it an R34 thing? Or aquaplaning in general. I used to try to 're steer' (if that makes sense) when the car takes off in the front end, but that makes it worse i find, now i dont touch the steering wheel as the car aquaplanes and i find it grabs traction again and self corrects but its a bit freaky..... There has to be a better way to reduce the effects of aquaplaning.... surely ? How do racing cars do it? I recently saw a porsche that crashed on the news after it aquaplaned killing the two people inside. I know ive come close to all loss of control too. Any Advice is welcome. Thanks in advance.
Edited by nathanau
https://www.sau.com.au/forums/topic/373335-aquaplaning/
Heya check tyres for what ? besides the obvious poor tread ( mine r in excellent condition)
What type of tyres you got?
Will help if you got a set of tyres that have good wet weather rating...
Hard and Soft tyres (as in rubber type) can make a difference too.
https://www.sau.com.au/forums/topic/373335-aquaplaning/#findComment-5954905
run tyre pressures UP 10 + lbs more then than normal
That's going a bit overboard. 2-3 psi would be more than enough.
Make sure you have enough tread on the tyres will obviously help - aids in dispersing the water from under the tyre.
Can't recall ever having a problem with aquaplaning (R32), running both Bridgestone Potenza and various Falken tyres. The crap Maxxiss on my Falcon are another thing all together.
https://www.sau.com.au/forums/topic/373335-aquaplaning/#findComment-5956123
tyre compound plays as big a part as tread depth, and tread pattern plays a big part too, especially if you have directional tyres and have rotated them yourself and put them on the wrong side. size also plays a big part. if you have wide tyres then they will aquaplane more than skinnier tyres.
and +1 for altering tyre pressure.
having said all of that, i've had some pretty shitty, almost bald tyres on cars before and never had any issues with aquaplaning. had a few moments where it's been close in absolutely pissing down rain though. maybe it has something to do with driving style as well.
oh and you don't use tyre shine by any chance do you? if you do, do you put any on the tread of the tyre? cause that's a big no no.
https://www.sau.com.au/forums/topic/373335-aquaplaning/#findComment-5956140
Damn, everything I wanted to say was mentioned lol.
But I have to reinforce, if you're not in complete control of the car, slow it down. It's just not worth it if things go wrong. Bad tyres, poor tread, low pressures, all make a pretty big difference. But there's nothing more important than driving to the conditions.
https://www.sau.com.au/forums/topic/373335-aquaplaning/#findComment-5958286
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
