If they are bolted to your hub then they aren't illegal as far as i know... only the ones that sit loose are dangerous/illegal??
I have R34 GTR wheels on my 33GTR and recon it would look alot better with spacers... i love these wheels and dont want another set - so what else could i do besides spacers?
Anyone got any?
sidewaymambo - do you mind if i ask you a few details?
What spacers did you get?
how much did they space your wheels by?
have you noticed any difference in driving/handling?
how much did they cost you?
is it as simple as just taking your wheel off, bolting the spacer in, then bolting your wheel back on?
do you have any before/after photos of your car?
THanks :P
answer:
1) A&T-R
2) 30mm for the front, 20mm for the rear.
3) Less under-steer, went a few tracl day, much better in conoring.
4) PM me for the cost..
5) yes, very simple installation, however I went to my mechanic's place borrow the torque wrench for the right tightness..
6) I don't have pics, but they line up with guard..looks sexy..
and they give you wider track = better handling:)
v8skylineman, have you never done any illegal mods to your car?
Yes I have, but what sort of person would I be to promote illegal activities.....
I have spacers and they do all the things everyone has said they do, but they are still illegal.....(in QLD anyway)
yeh i have the same type of spacer as sidewaymambo, cept mine are purple color. they bolt onto the hub and is just the matter of putting on the bolts onto the hub. as far as any problems i don't see to have any. i will be taking them off and selling them soon tho as im getting new rims.
Geeze,
From what u guys are saying, i better not buy any set of rims that "don't fit my r33"......GOR33 is selling his set and says u need spacers to clear the front brakes, I was really keen to get the rims (For Sale Section title "18's rims for sale") .....anyone recommend i get them?
umm... i'm not sure exactly but when i pull them off to fit on new rims i can measure it for you. I use it on a r33 gtst.
how much i plan on selling them? i'm not sure.. nothing much.. i'll see when i pull them off and take pics and msg you and we'll go from there i guess.
im in queensland and have been told by many engineers that they are legal,safe and practicle, provided they are the bolt on adapters. and for around $150, i think they are a good consideration if nice rims are in question.
ive already posted a thread on this topic if u want to look back and find out what i was told about them.......basicly its up to u, some people would rather not use them, others dont mind, it depends on the person, however as far as i know they are fine, hey , ive been told wide body porches have them, if its ok for porche then its good enough for me!
You can buy 2mm, 4mm, 8mm spacers in a die cast metal. They sit on the stud bolts, but are only held tight once the wheel is on and the nuts are put on. The other downside of these is that they shorten the length of your studs. You can buy the cheap spacers for about $25 a pair depending on thickness at any good tyre store or performance shop!
yeh i think they are the ilegal type boj01, they have to be bolt on items,and whats this russian roulette business, gee some people have a wild imagination, look if you are useing them on a race track and for heavy drifting and stuff then yeh i might be a tad concerned, but having them on for everyday street use, i cant see where the huge problem will be. and whats all this talk about putting huge strain on wheel bearings and axles, where does stress go when ya sideways around a corner doing 100 km/h on a normal set up, and how does ya gearbox like high rev luanches at every traffic light?
like i said before everyone has a different opinion, if u have them on with intentions to take it easy then there shouldnt be a problem, but if you want to thrash ya car, then the spacers, along with other things, will always cuase you problems.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
