  • Replies 180
Errr....  Hope I haven't stepped outta line :) but I kinda went and gee'd the Streetcommodores.com community up for an SAU vs. SC battle.
Step up Skyliners!!!
Adrian
Last time I was at WSID I raced a VX Clubsport, for some unknown reason he didn't even make it past the 60ft line :P
Bring it on :wavey:
damn these tunes seem never ending...eh..
if interested i have x2 guys coming from Japan in 3weeks to do some tuning with my car and another one...if interested let me know..
they have done extensive training with the PFC and the FCON. As well as tune major the major ones e.g Motec, Autronic, EMS, Haltech.
They will tune initially on the Dyno and then we are going to hopefully hire wakefield for the day :P
He smashed his diff to BITS!!! Trailered home :D
Hey judd, make sure the jap guys don't tune your car with a 10.8:1 AFR as is so common. Otherwise you'll become really quick at changing plugs in a short amount of time. i.e. after driving to and from the shops. :rant:
Adrian
omg
Street Commodores vs. SAU .... what the **** do I do, what team am I on?
Oh well, I cant wait to get out there if this workshop will give me my car, its really starting to (you know what) me.
Rick, will be awesome we can race and when I beat you you must fulfil your part of our bet!
Cant wait
Evan
Nope, not driving an hour past the track in the other direction ;)
Adrian
;):werd:
Probably cruise down with YRL05S.
count me 95% in... gotta convince bec that my car wont blow up.. :(
I'll Bring Jody, tell her that we are only going to watch... get a conversation started between them and have 11 or 12 runs... doubt she will even notice! :D
omg
Easy, if you win your with us... loose and your with them! :rofl:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
