does it matter if its legal or not? why bother installing an anti-lag system unless its a track/rally dedicated car??
..it aint gunna get you to westfield any quicker.
Edited by adamskill
You signed up onto SAU to ask whether shooting 1m flames from your exhaust at a set of traffic lights is illegal.....hmmm let me think....
Jokes aside, ive always wondered how antilag works. Very interesting read on wikipedia, like how the restrictors they use create more lag then a normal sports car so the turbo needs to be going stronger before they put the foot down.
http://en.wikipedia.org/wiki/Antilag_system
on the street would be useful if you had a larger turbine and wanted to go on a spirited drive, although its probably very illegal and probably harsh on your powertrain.
I would think the exhaust with mufflers and cat converter would be blown out in a few minutes on the street.
definitely belongs in motorsport though.
Its not stress on the drivetrain you need to worry about.
Its stress on the motor/turbo. That's where the issue is. You'll be replacing turbos quite often if its used even semi-regularly.
thats what i meen,he would be burning through exhaust valves quicker then the turbo though.
I setup antilag on the Vipec for shits and giggles (it's not 100% setup as I'm not that keen on it). Definetely not good for your car though.
You sure Evos have it from factory? What models? I've never heard that before that's all.
You mean proper antilag for between gear changes or just launch control antilag? (I wrote up a post in the past explaining all the different things people refer antilag to but can't be bothered finding it).
Evos do not have antilag from factory.... I used to have one and two of my good mates have them
some of them do. it is a pretty watered down system though. also in some cases it is disabled in the ecu. basically it is put on there as a provision to get around certain homogolation regulations in certian rally classes (group N i think). so basically some of them have all the gear, but it isn't turned on. not sure what models do and don't, but all i know is that the info above generally applies to the evo 3
Most evo's have the "missfiring system" from the factory, it is something that can be turned on in the ECU ( many of the evo ECU's are factory flashable)
You can see the pipework in an OEM engine bay !
However many owners can and do remove it, because for most people having it is irrelevant.
Also,
If one forces sex upon a prostitute is it rape or shoplifting ?
    • According to this https://torquecafe.com/nissan-news-skyline-manual-twin-turbo-v6/
    • Oh I don't want to get into the details of the 1.5way, @Kinkstaah is the one that holds all the wealth.
    • Dose will be able to confirm this more, but a 1.5 way IS a 2 way. It's just not as aggressive on one of the ramps. Changing from 2 to 1.5 I'm not sure how though.
    • No updates on the car but figured I'd share a nice outing. All the recent work paid off and I got it all together and out the shed for a car based pre-wedding celebration for a good mate of mine. Pretty casual cruise through the hills to a pub for lunch then out for some go-karting at The Bend. Headed down to Myponga for the night We stopped in at the reservoir before heading out down to the coast for lunch via the dam  By the end of the weekend away I covered 350km and the 32 generally behaved its self. A good Shake down after being apart before the Track day in a few weeks
    • The front prop shaft from my GTR had very notchy unis, which obviously needed replacement but unfortunately uses the (usually) non-replaceable (staked) type.     A new shaft is something like $2K plus shipping from Japan.   I wouldn't even bother asking the local Nissan spares dept.     Rang Hardy Spicer but no go, which surprised me a little.     There's a place over Dandenong way that would make me a 'performance' shaft but un-necessary in my situation.   They claimed to be getting the equipment in to replace staked unis but couldn't give me a timeframe.   Anyway, long story short, found a place to do the work just 5 mins from me: https://knoxdriveshafts.com.au $420 (cash) and about a week later I have my driveshaft back.   Price includes balancing. Owner is a one man band working out of a shed in his backyard but from what I could see he's very well setup with some expensive equipment.
