The car
Stock R33 1996 S2 skyline,
I have talked to a few people about the possible issue, thought i might make a post. Gears 3,4,5 at 3-4k rpm will hesistate or die down.
Example 1,
I can get to 4,000 RPM then it would drop down to 3-3.5k, with my foot on the accelerator still.
It will hold at 3-4k rpm for a few seconds before going any further beyond,
hopefully thats enough information, i just changed my spark plugs, coilpacks look fine.
any ideas?
https://www.sau.com.au/forums/topic/374350-rpm-boost-issue/
this is what a clutch does when it is warn out and slips
it free revs higher then slips and so forth
baby it around and get a new clutch
if you keep pushing it, it will fail, and take the flywheel with it
the stock clutch is pretty basic and not geared up for heavy use
https://www.sau.com.au/forums/topic/374350-rpm-boost-issue/#findComment-5975317
how on earth do you reach that conclusion?
if the AFM is a fault, rev cut is 2500rpm and the ecu does hard fuel cut, thus you cannot rev past 2500rpm
if spark is breaking down the engine misfires its ass off but the rev needle doesn't slip
if the clutch is slipping or worn the engine revs until peak torque, around 3500rpm (on boost) and slips and then re-grips when past peak torque
so i have no idea how you believe its afm or spark
but good luck
https://www.sau.com.au/forums/topic/374350-rpm-boost-issue/#findComment-5976972
but good luck
Apologies, i didn't read correctly/understand it wasn't actually a misfire, i just read hesitation and assumed. As for AFM i've seen a few give bad readings at certain outputs, but still within what the ECU sees as 'acceptable'. The 2500cut will only happen if the voltage is either missing, or way out of range.
Edited by _x_FiReStOrM_x_
https://www.sau.com.au/forums/topic/374350-rpm-boost-issue/#findComment-5977100
even if the afm is mangled under certian conditions
the worst it woudl do is give incorrect load reading, either lean out or richen up (smoke or pinging)
it doesnt explain the RPM needle going from 4000 down to 3,500 or 3,000 with the accel pedal still pressed
nothing matches the symptom with the problem other than a clutch slipping or auto box toast (if its auto), which is still a clutch
no afm, map sensor, intake pipe, external wastegate, blah blah would make the needle slip like that
https://www.sau.com.au/forums/topic/374350-rpm-boost-issue/#findComment-5977173
It seems out opinions may differ :).
Nevertheless it may be a clutch at fault, i'm not ruling that out at all. From what i've seen with clutches though, generally once the grip is overcome and it begins to slip it heats up rapidly and then continues to slip until you release load from it and it cools. - instead of slip-slip then suddenly grip. The OP needs to describe things a little more i think.
https://www.sau.com.au/forums/topic/374350-rpm-boost-issue/#findComment-5977220
Doesn't sound like a clutch slipping.... He said it feels like its dieing down and revs drop, rather than rapidly increase. It takes that little moment for it to kick back in and move again. You need to describe the problem further.. What it happens, do you get any popping or machine gun sounds?
I had this issue twice, once it was misfire, the second time it was lean popping(failing fuel pump) and with the lean popping there was no way in shit stick I could get it past 4k.
https://www.sau.com.au/forums/topic/374350-rpm-boost-issue/#findComment-5977637
What about 4.5-5k does it do it then as well? Or specifically 3-4k ?
Are you running more boost than stock? Aftermarket intercooler? bigger exhaust? If yes then it is probably combination of bad spark and running way too rich, check plugs, plug gap (should be 0.8mm), and check coils for cracks and scalding marks.
If it is completely stock then it is probably a different issue as the above tends to cause a misfire at peak torque, not lower in the rev range.
Also is it those revs regardless of load, or with minimal throttle will it rev out cleanly and it is only on WOT that it happens? Does the engine completely die or does it msifire (eg pop pop pop and lots of black smoke) ?
Need more information.
Edited by Rolls
https://www.sau.com.au/forums/topic/374350-rpm-boost-issue/#findComment-5978680
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
