I have done a search but cant find a definate answer....Engine is rb26dett.
If using twin 044's, with twin entry rail etc, will 800cc injectors be ok if i just bump up the rail pressure, and If so to what power level?
My 800s are pretty much brand new sards so If I could keep them instead of having to buy new ones that would obviously be the go.
Any help is much appreciated. Cheers
  • Replies 74
Given he asked what power level - estimated you'd say 400rwkw would be the limit. Maybe a tad more, maybe a tad less.
With bumped rail pressure my 700cc Sards are @ 65% max duty with 360rwkw on PULP (20psi).
So 400rwkw on 700cc/E85 (allowing for 35% extra fuel) would be 100% duty with the bumped rail pressure.
So you could say the 800cc on a 2.6ltr might just scrape in. But you won't know till you get there.
We have seen a couple now max 1200's at 600hp on the nose at the wheels. That is tuned logging individual cylinder EGT's.
The others that we have done seem to come in at around the same ratio so I would say 400hp at the wheels would be a fair guess as to what you could make safely on 800cc injectors but as N1 said, every setup is different and it will all come down to fuel flow and the rest of your setup.
The car we just had tuned on 1600's made 610 on 22psi and uses just over 9L/min of fuel at peak power. Not sure on the duty cycle yet but I can report back if anyone is interested (could calculate also but not sure on the exact L/min rate right now).
We are also about to wind 2 bar into it and crack 700 at the wheels. I can report findings on fuel flow and injector duty if it will help you guys out?
Yeah cause as we've seen, some tuners love 10:1 AFR's lol.
That is certainly going to damage the duty cycle.
And rightly so. If you can't run 10:1 in places of your tune then your fuel system is inadequate.
Every car we have tuned runs 10:1/10.5:1 at some point. Usually at peak torque or there abouts. But then again, none of the stuff we have tuned anymore ever blows up....ever and it's only since using this tuner
Ok well I wasn't really after a smart arse answer, I realise every setup is different but anyway the car is running dash 5-s, vipec, cams, etc.
At the moment it only has single 044 intank at 320rwkw
I have a fuel system for it consisting of 2x 044 twin entry rail and at the moment only the 800cc injectors fitted.
Wow have you got a flow gauge that does 9l/min - where do I get one of those?
You trolling me or are you just clueless?
Calculated fuel flow based on the EXACT ms open time of the injector at peak power. The injectors are being told to deliver that exact amount of fuel. So where to get one? windows has a calculator or you can buy one from any newsagent
I'm now seeing 620 rwhp on E85 with CDI ignition allowing/accepting much more fuel. This is despite my modererate 2860-5 low mount turbo setup. My HKS 1000 CC injectors are at full duty cycle at max torque.
In hindsight, I would have gone to ID2000 (2000cc) injectors as the HKS units weren't "plug and play" in any case.
I'll take the opportunity again to express how impressed I am with the billet.net.au CDI kit (M&W CDI + bracket + harness etc). The spark strength allows bullsh*t amounts of E85 fueling midrange and just wakes up the turbo response. Forget your Splitfire/Twinpower combo.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
