wont you need new front guards and have the holes in the rear quarters filled too?
not to mention the side skirts wont fit as they have the wheel arch cutouts in them
just paint the whole kit aaron
yep will be doing this. with an axis front if i can get it down here from brisbane. otherwise ill start hunting IM.
Ahhh, I see (slaps forehead). Then what I was meaning was turn it into a flare-less RS/RX look. But if there is heaps of work required to patch up bodywork after the flares come off....better not to bother.
Edit: thanks Iain, you answered my question.
too much work actually. i explained to cam what the panel beaters told me when I asked about it a while ago.
the holed need to be welded up, then bogged once cooled etc. they said after time because the metals are different(aged etc) the bog will crack after it expands.
Price is in your inbox mate.
thanks. yep tell her to order it for me man.
Agreed.
Steps to transform ugly ARX into not-ugly :P
1. Acquire Axis front and rear bars
2. Get a custom grill made up (or pay through the arse for Axis grill, bonnet ornament and backing)
3. Colour code the lot
the bar im looking at comes with the grill.. ill have to get an ornament made up for the bonnet though, no rush.
Done.
I'll let you know when you can pick it up.
Or just run it without the bonnet ornament.
It blocks out too much airflow anyway :P
Done.
thanks man,
yeh i bought the bar, im not fussed about the bonnet bit. i dont think it will be very noticable, especially if i decide to hack it.
thanks man,
Did someone say a slice of 0.9mm Stainless and some double sided tape?:P
Interested in offloading your grille?:wave:
I actually like the look of the ARX, I reckon non-ARX models look like they have "too much body" at the back end if that makes sense???
I must be weird... an ARXophile
I would consider colour coding the kit, but I have seen varing results depending on the colour.
:cheers:
Whenever you like mate; I'm in no hurry.
Hopefully whoever does your paint works faster than my guy...
lol yeh i might wait abit first thought depennding on funds..
ill get the grill to you quickly coz ill just throw the front bar on so yeh..
lol it looks gay in white
i didnt end up getting the axis bar. guy was being dodgy and didnt want to accept paypal even though its an ebay purchase. oh well next time.
Isn't that against ebay Terms of Service.
yep. but i havent made the transaction yet so couldnt give two shits, let alone 1
My sister had to report someone for that once. She automatically paid via paypal, then the guy said he didn't accept Paypal, and wouldn't transfer the goods until he paid by bank transfer.
Gee the gene pool is shallow in some spots...
  • 6 years later...
Apologies for bringing up an old topic.
My drivers side front fender flare flew off on Pittwater rd a few weeks ago. I'm struggling to find a replacement, just thought I would check here if anyone is wrecking an ARX or have any spares they would like to sell me? :)
Amayama wants north of $400 delivered.  Part number is 63810-AQ100
I am aware of the few ARX's wrecking on eBay at the moment, but they have either been sold, or the fender flare is glued on so the guy wants to sell me whole guard.
Long shot, I know. But cheers anyway :91_thumbsup:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
