so had the 31 clubs dyno day today down at boostin oz in salisbury.
was an awesome day.
laurel performed well and pretty much on par with what i was expecting.
made 167.7rwkw on the first run and then 167.6 on the second. afr's are out to the shit house. rich/lean/rich/lean haha.
finally found an r32 ecu which i recieved today, so will be gettin nistuned this week then off to boostworx for a remap. hopefully can push up near 200.
will have some pics and vids up soon once they upload
yes as nick as stated all a31/c33 ecu's are poo for tunning/power , they basicly have a heart beat of lean AFR's which do them no good when its time to tune/ make more power, i even noticed nearly all hunting issues gone and a smoother run once i ran a r32 ecu in, credits to trent at checkered tunning for giving me the heads up :thumbsup:
note, pretty sure i stated the same thing in this very thread, fail! for not listening to my online gospel preaching :merli:
lol yeah you said not to bother tuning the laurel ecu.
and so i havent. just didnt realise there was a difference in tune from standard plus i was bein lazy :P
but it is good to know and will be in tomorrow night and nistune on thursday. then hopefully only a couple weeks till full remap :)
ok new ecu is in. havent driven it. apparently its out of a late model 32
part number is mec-r212
instantly seems better. started the car up and the idle is 100% better then with the laurel ecu.
nistune will be installed this week some time. and tune soon
i believe its actually an mec-r212b
on the case it has mec-r212 in one box and then next to it is a b and then in the next box 2703
according to matt (guy who made nistune) it will be fine.
i have just taken it for a decent drive. did about 60ks.
seems fine idle is great, revs smoothly. and fuel consumption seems better already.
tryin to upload pic of the ecu itself but phone is bein a moron
ok pics.
judging by the writing on it in the second pic its come from a wrecker at some point. so im assuming its the right thing...
either way accordin to matt even if its a non turbo computer for all intentions its exactly the same. once the turbo map is put on it itll be just like a stock 20det ecu.
so i decided that "a little elbow grease" was way to hard.
yesturday i bought a buff pad that is for a drill, bought my drill home from work this morning and went at one of the wheels with it along with some liquid autosol.
results are awesome.
this is after about 10mins. only done the spokes, 90% of the water marks are gone.
once i get the spokes out of the barrels ill go over it properly along with the rim.
id brought what i thought were the appropriate sized socket and spanner home... turns out volk uses 10mm bolt heads and 10mm nuts.
where as work uses 8mm bolt heads and 12mm nuts. haha
this hasnt actually discoloured as you can tell from the previous pic. im assuming its the reflection from my high vis orange work shirt haha.
here is an untouch wheel for reference.
anyone got any ideas on how to get the bolts all shiny again? i was thinkin just soak them in a light acid. they destroyed the buff pad i was usin. and cbf doin it by hand.
alternatively thinkin about paintin them black for some contrast?
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
