given I can put my hand on mone and almost get a burn off it - yes it is needed and I do agree with teh above statement. heat kills these things - I have a $4500 bill to prove it.
Yeah for sure I support that, they get HOT enough for cooling to be a concern. But what I'm wondering if the oil taking too long to warm up is a concern. My new radiator won't have the "cooler" (warmer) built in, and whether or not that is a concern on the cold mornings I'm not sure.
  • Replies 44
Posted Images
of course they would be too hot to touch, they shed heat into the engine coolant which ranges from 80-110 degrees lol
just plumb one of the pipes next to a radiator pipe (even touching it) and youll get a bit of heat transfer
if this theory works, i'de just be mounting the external cooler so it is physically touching the radiator core. or is this bad?(dont flame me it isnt how mine it lol)
thats how i have mine setup right now. im sure there isnt MUCH heat transfer, ideally youd want the pipework inside the radiator fluid, but this is the best option i had till my new radiator goes in
Looks like B&M SuperCoolers are the go.. http://www.bmracing.com/PRODUCTS/Automatic-Transmission-SuperCoolers
‘LPD’ or Low Pressure Drop feature includes two bypass channels nearest the fittings to allow fluid to flow freely especially when cold to prevent lube system failure.
That's for a 11x7.25x0.75in unit which seems pretty similar in size to what everyone else is running. They have larger units but the fittings are larger too which would be a bit of a pain. If you're in a lot of city traffic they also have the same coolers with fans on them.
Chuckie this is exactly what I want. Can you still pick them up new from Mazda? Or do you need to find a second hand unit?
I was taking to a mate about this exact cooler last night; he reckoned Mazda charges $400 brand new. Supposed to be an incredibly efficient cooler for it's size.
if youre not moving there is probably no point in having a fan on a transmission cooler. once youre moving and you need the cooler to work, well, youre moving!
Unless you are sitting in peak hour traffic in summer.
But if you mount it above the reo, the engine fan will pull air through it anyway :)
I have one of these in my R33 with modded C4 auto.
http://www.onautos.com.au/epages/opa.sf/en_AU/?ObjectPath=/Shops/opa/Products/PW05388
But am now worried it wont be enough so am looking to get a 30 row oil cooler core and use that with a fan. I also have a transbrake and was told to box will see 120+ degrees within a few seconds on the transbrake.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
