Yeah but they aren't too familiar with rb's, they seem more rotary based.
Is hard to find someone who knows rb's n/a cars and haltechs with out the "that will do" or "that's close enough" attitude
aim is to have it ready well before the all jap day at silverwater on Nov 13 and there is stuff i need to do outside the tune
thought you went to castle hill exhaust
(oh and im trying to find someone close to sea level as possible as you know my car doesnt have an altitude adjuster :P )
next week ill start calling up the tuners that i have in mind, will keep everyone updated
Got a call from Mick first thing this morning, and there may have been a bit of misinterpretation on my part,
mick said that he said; i got to have all these cars ready for a race meet which all these and these i sponsor have to be ready for the long weekend
so my bad in my part there
but yeah he also hadn't realised it had been there for so long and said im right to have the shits but he has promised that nothing else will leave his shop until my car is done
So yeah we'll see how it goes from here
I doubt he reads the forums, and ive also had heaps of time to build joels rb26/30de and make it all 100% like brand new & perfect. But i guess having a whinge gets things moving
though still need to fit the oil cooler, new oil and filter and plugs (after its run in), fit and adjust the new coilovers, fit the catch can, give it a decent wash and go for a pie run and drive to new castle all before 13th of November
Will up load pics, dyno sheet pic and a couple vids tonight (no driving videos, as i was driving)
But f**k me its fun to drive.... light goes green, slight hesitation then at speed limit before i get to change to 2nd, and i haven't tried full throttle yet, more trying to keep it on the speed limit for now :D
No skids i like my licence, (if there were i wouldn't post it :P )
and my phone decibel app says its at 98 decibel at idle... will need to get that checked out
Pictures
RB26/30DE extractors and shiney stuff
RB26/30DE - Painted cam covers to match car with carbon & black and grey carbon fibre timing / valley covers
RB26/30DE - ram tudes, velocity stacks, trumpets, shiney round things, what ever you call them
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
