The air temperature is right as much as we need the wet stuff i wish it would buzz off for me lol
Hopefully it is dry tomorrow.
I knew I was there for a reason and it wasn't to get my hands dirty...lol
Oops 16 deg and raining is the forecast
Great news :) I look forward to hearing your final results when the tune is finished and when you get some dry weather!!
Thats a bugger mate but i can tell you that you will be happy with your turbo selection from my first feel of my car today and the sound is good too :)
Thanks Andrew, glad u were there to give me a few neat little tricks especially the one on how U remove the side feed injectors from the rail. Loved that one.
Did a tiny bit of road tuning. Was wet and scary, but so far so good. Turbo is nice and responsive and has an awesome sound.
I just got home and left at 6 this morning. So a 16hr day. I couldnt leave micko there without getting it finished, i could tell he had been itching to drive it since he started ordering all the parts.
man when i said it should be easy for you, I thought you had a shop ..wait u do have a shop dont you..im confused :unsure:..
Anyway ,good work fellas :thumbsup:
Haha cheers ive got an engineering workshop artz still got a bit of work to do yet like putting the blow off valve plumback line in and modify the turbo outlet pipe my cat needs the flanges cutting off to align them better cos of my new dump pipe i think, gotta put my turbo blanket on get my cam gears installed waiting on a tomei fuel pump thats goin in and finally get her tuned properly as the wet weather blew any chance of bringing her onto boost...
When i finally finish it properly i will post some up...
Think im gunna get Jez to tune it up on 98 and see how it feels then on 11th next month i will have Yuvas re tune it on E85 and see what the difference is :D
Just got back from taking it for a buzz then Jez feels nice when it comes on boost but i been shifting at bout 4500-5000 and 51% throttle is most ive used so full throttle and more revs should be awesome hoping a good tune will help bring it on to boost a lil earlier though :thumbsup: gunna re run the pipework tomorrow when it comes back from the exhaust shop got lazy yesterday with that miserable weather didnt even clean the workshop lol. Got a boost control issue too my peak hold was 16.3psi when my controller was set to 13psi so dunno whats going on there :whistling:
How did u go with the new piping Micko?
have u takin it for a rap in the dry yet?
Ok so it was my first drive in the dry today so it was good to feel what she pulled like with some boost. In second gear and around the 4300rpm zone it started to spin my 255s (unsure of boost pressure) which was surprising actually considering my car has a 2 way kaaz LSD , it hasnt been tuned and it was just under half throttle 49%
It initially felt like a bit laggiier than i was expecting but jez pulled some timing out of her to make her safe albeit we couldnt drive her safely in the wet up top.
Just wondering roughly how much the tune will help boost response?:rolleyes:
f**k all unless something is completely wrong.
Ok so today i made up a suction pipe and my turbo outlet pipe out of 316L stainless steel and purged welded them i also chopped up and modified the factory blow off valve plumback line for my turbo today just gotta clamp it all up tomorrow. here is some pics of my work :ph34r:
:thumbsup: HAHA was thinking dunny rolls woulda looked better but settled for stainless instead! Thanks mate it did come up good i havent polished it up yet it will come up shinier but thats tomorrow arvos plan
My mig welding is heaps sexier than ur purged tig welds. Looks awesome micko well done.
So where is the pics of your pringles can mock up lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
