The thing I'm most interested in is where it starts building power etc, its clear that with >20psi and E85 its going to make good power - that was never the question. I'm more interested to see if its equal to or any better than a regular GT3076R in normal usage.
if i can get this footage to actually work it probably wont give you a good idea lithium as i was sitting on 4-4500 before i could give the accelerator a hit
The vid actually tells very little in general, looks quite laggy in 2nd gear (though you say its not necessarily full throttle?) and breaks loose a bit in 3rd. Seems like it must go ok though, take it to the strip and point a camera at the dash :D
Yeah prob not the best video lol yeah hit bit of a dip in the road in 3rd and it started to squeal i dont think it feels that laggy in 2nd tbh and yes i will hit the strip so i can do a decent in car video.
Just spoke to my tuner and the engine light popped on because i was about to hit the rev limiter and thats the links little warning telling you you are about to get cut so thats a relief :blush:
Yeah that's what i wondered... My tune will be E85 and probably 20psi with the 3037-56T but would be interesting to see how different it would be with the GTX3071r as a back to back comparison... Maybe one day i'll do it but for now ill concentrate on just getting my car to run >_<
What r u guys complaining about, it looks fast enough (4500rpms to limiter) for me to jizz in my pants, does look real fast, that zone. But I understand the first half of the rpm band was slow as cos he wasn't flooring it as above?:rolleyes:
Interesting. My link doesnt flash a warning when i hit the limiter. It does if you bash the MAP limit however :)
Maybe its a setting.
I think you should take a few more videos like that one.
Do this:
2nd from 2000rpm
3rd from 2000rpm
4th from 2000rpm
Quite keen to see the difference in real time recordings between the GT and the GTX
I have a video quite similar to that one you just posted. Dont know if Lithium or myself have already posted it? (Normal GT30)
Yeah cpouldnt floor it when i wanted cos there was a truck in front of me so had to let him pull a gap and a falcon coming the other way that looked like popo from a distance :whistling: so didnt step on it till 4500 really
My tuner told me that it will flash for 3 reasons nearly hitting the rev limiter, boost cut if it over boosts and temperature which is how mine is setup apparently.
I will do some more in car vids when i can actually get on it harder..... Hopefully this shitty weather pisses off it looks like its gunna storm out my way soon.
Do this:
2nd from 2000rpm
3rd from 2000rpm
4th from 2000rpm
I ditched the boost gauge my profec is my boost gauge :whistling: but i will do my best to get some more footage as soon as possible as long as the weather holds out for me
Profec is good, because you can show a peak hold value!
So load up in 4th from 3000rpm with camera on tacho, then when you hit 1bar back off and show the profec peak reading!
For science :)
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
