The thing I'm most interested in is where it starts building power etc, its clear that with >20psi and E85 its going to make good power - that was never the question. I'm more interested to see if its equal to or any better than a regular GT3076R in normal usage.
if i can get this footage to actually work it probably wont give you a good idea lithium as i was sitting on 4-4500 before i could give the accelerator a hit
The vid actually tells very little in general, looks quite laggy in 2nd gear (though you say its not necessarily full throttle?) and breaks loose a bit in 3rd. Seems like it must go ok though, take it to the strip and point a camera at the dash :D
Yeah prob not the best video lol yeah hit bit of a dip in the road in 3rd and it started to squeal i dont think it feels that laggy in 2nd tbh and yes i will hit the strip so i can do a decent in car video.
Just spoke to my tuner and the engine light popped on because i was about to hit the rev limiter and thats the links little warning telling you you are about to get cut so thats a relief :blush:
Yeah that's what i wondered... My tune will be E85 and probably 20psi with the 3037-56T but would be interesting to see how different it would be with the GTX3071r as a back to back comparison... Maybe one day i'll do it but for now ill concentrate on just getting my car to run >_<
What r u guys complaining about, it looks fast enough (4500rpms to limiter) for me to jizz in my pants, does look real fast, that zone. But I understand the first half of the rpm band was slow as cos he wasn't flooring it as above?:rolleyes:
Interesting. My link doesnt flash a warning when i hit the limiter. It does if you bash the MAP limit however :)
Maybe its a setting.
I think you should take a few more videos like that one.
Do this:
2nd from 2000rpm
3rd from 2000rpm
4th from 2000rpm
Quite keen to see the difference in real time recordings between the GT and the GTX
I have a video quite similar to that one you just posted. Dont know if Lithium or myself have already posted it? (Normal GT30)
Yeah cpouldnt floor it when i wanted cos there was a truck in front of me so had to let him pull a gap and a falcon coming the other way that looked like popo from a distance :whistling: so didnt step on it till 4500 really
My tuner told me that it will flash for 3 reasons nearly hitting the rev limiter, boost cut if it over boosts and temperature which is how mine is setup apparently.
I will do some more in car vids when i can actually get on it harder..... Hopefully this shitty weather pisses off it looks like its gunna storm out my way soon.
Do this:
2nd from 2000rpm
3rd from 2000rpm
4th from 2000rpm
I ditched the boost gauge my profec is my boost gauge :whistling: but i will do my best to get some more footage as soon as possible as long as the weather holds out for me
Profec is good, because you can show a peak hold value!
So load up in 4th from 3000rpm with camera on tacho, then when you hit 1bar back off and show the profec peak reading!
For science :)
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
