If you can put a LS1 in to a skyline im shore a XR6T can go in with time and money.
ls1 would go in easier than a ford straight 6 (v8 is shorter and lower and lighter). as i said in the other thread the OP started asking this, issue would be with the height of the motor and the weight (they are an iron block, not alloy, although the head is alloy), and possibly the length. but if it's a track car then you can easily overcome the size issues with a bit of creative panel beating, but it may still handle like a bucket of crap because of the weight.
RB26 weighs in at around 180kgs bare, the Barra engine around 175kgs bare.
Ancillaries would be similar weight.
RBs are iron block, so that's a moot point.
Block height difference might be a bit, but even if it's 40mm, that' be pretty easy to overcome with engine mounts and/or a bulge in the bonnet.
I reckon a 4Lt in a 32 would be a f**king weapon.
It's not a bad fit.
Height is a slight issue but nothing major, if using an FG rear sump engine it will require modifications.
I've got one in an r32 gtst and an r34 GTT.
Also developing a 4 bolt main sump/diff for an awd conversion.
We figured it'd be a wanted component.
Weve been playing with FG and BF engines for a while now. Have a dry dumped FG engine going into an r34 and also another BA engine going into an r32 GTsT for track school shortly.
The awd sump is a work in progress but very possible
I'll use a WRX gearbox and hope for the best..........
That's sarcastic by the way....
I LOLed.
This is what happened the last time someone tried to run 1000nm of twist through a WRX box.
I was thinking about buying one of these set ups from you, but seeing as my honest questions get bullshit answers I won't bother
Well you have to admit it was a kinda of obvious question, wasn't it??
My reply wasn't intended to offend.
It has to retain a GTR gearbox.
As for how I'll make it work properly, that's what I do for a living, it's all custom fabrication.
Jeez, talk about humour fail.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
