Hello everyone i didn't know if i should post this in the turbo upgrade sticky, but i didn't upgrade my turbos. so i decided to add it here.
i have attached 2 dyno graphs one with standard AFM and one with Z32 AFM. i did this so new people can see how much power they can get for this modification. But remember this is how much i gained on my car, every car is different depending on mods/age/worn engine ect.... But in my instance i gained 17rwkw from adding Z32AFM to my car. Hope this helps you in deciding what mods you wanna do to your car in the future :thumbsup:.
https://www.sau.com.au/forums/topic/375532-dyno-tune/
Isn't this just standard AFM pushed to max then putting a better AFM on with a larger scope and tuning to suit and getting more power
I don't think if you had for example 190rwkw you would necessarily gain power just by adding a Z32 AFM
https://www.sau.com.au/forums/topic/375532-dyno-tune/#findComment-5989764
You should find that the z32 air flow meters will give you a larger tuning resolution that the stock ones,
but there really is no way that the Z32 AFM's can give you a power increase on their own.
The stock AFM's will run out of resolution/max out and have no more Voltage range to give at approx 300rwkw, i have had this exactly on my own car, then the Z32's are installed to give tuning resolution past this mark.
The power gain you have shown is most likely because of a diferent day on the dyno, some other modification you performed, or most likely it is running a bit leaner on boost or have more ignition timing.
Not having a go at you, just letting you and others know, that AFM's, just like upgrading fuel pumps and injectors will not give any power increase, but they will support more power.
The only other way a pair of Z32's will give more power on their own would be if the stock 65mm AFM size was restricting the motor and the 80mm size allowed the engine to breath better. The Nismo AFM's are 65mm though, with the tuning resolution of the Z32 AFM, so really, unless we are looking at 550+rwkw, i cant see that being the case :thumbsup:.
https://www.sau.com.au/forums/topic/375532-dyno-tune/#findComment-5989781
Yeah Z32 won't give you more power.
Any extra power would come from tune adjustments, boost, dyno variance etc.
Could even be the old AFM's were on the way out for instance. Or you had a minor leak, so replacing/refitting piping removed that etc. Plenty of reasons why there is more power - the AFM's though ain't one of them.
https://www.sau.com.au/forums/topic/375532-dyno-tune/#findComment-5989816
Hence i'm showing that having Z32AFM would give you more potential to make more power over stock items, off course to make the extra power you would need a proper dyno tune and other mods (that's why i added the mods done listed on 1st graph).
https://www.sau.com.au/forums/topic/375532-dyno-tune/#findComment-5990155
No you said: "how much power people can get from this modification".
That is distinctly different to "give you more potential to make more power ".
The AFM swap did not give you power. Something else did.
It's common knowledge a Z32 or Nismo AFM will 'read' more air than a stock AFM.
Either way @ 250rwkw, your stock AFMs were not maxed out.
https://www.sau.com.au/forums/topic/375532-dyno-tune/#findComment-5990177
Just that part there may have been a poor choice of words. I get what your saying
But the way you put it just sounds like you mean "Put a Z32 AFM on and you'll get more power"
Question but for the more experienced users on here:
Say for a 150rwkw Skyline with a Power FC, just as an example - Would having a standard AFM be better then a Z32 as the resoloution isnt spread out so much? Or am I completely misunderstanding the idea behind this
The way I see it, if you have a 20x20 map on a stock AFM thats good for 150kw (I'm just using a random figure), then you have a 20x20 map with a Z32 AFM map thats good for 300kw (again hypothetical figure). You've got so many more cells to tune the amount of airflow for 150kw as its using all the cells rather then just half on the Z32.
This is just a question, as I've thought about this for a while and this is how I see it, I know that the Power FC intorpolates the 'in between' data, but still would be interesting to know if my assumption is right
Also thought the same applied for injectors? Get stupidly large injectors and you'll have plenty of room to breathe, but lose a bit of the fine tuning
Or am I completly wrong :thumbsup:
https://www.sau.com.au/forums/topic/375532-dyno-tune/#findComment-5990184
Well... Yeh, obviously lol.
This is like saying you had maxed your stock injectors at 200rwkw so you upgraded your injectors and now make 300rwkw, therefore the injectors gave you an additional 100rwkw. In reality it didn't, it was the other things you modified that gave you the power increase.
I'm not sure what you were trying to show by posting this? I mean is that not the exact reason everyone upgrades their AFM, because they have maxed their stock item?
https://www.sau.com.au/forums/topic/375532-dyno-tune/#findComment-5990185
if you set up the power fc to suit yes you would have more accuracy with a standard afm, but you'd be lucky to notice any difference. the afm voltage and power fc load points arent linear either, its exponential. for example, on the power fc base map for a rb25 the last load point (p20) is double p15 and nearly 4 times p10. its set up this way to give more accurate tuning under light load. also you can adjust the load points to suit but the base settings (which almost everyone uses until they max them) arent scaled to suit the standard afm, they suit up to and over 300rwkw without any resolution problems.
as for injectors the only reason you lose fine tuning is if the injectors cant atomize properly at idle and low load or if the ecu/injector drivers arent capable of opening them for short periods with enough accuracy. with a good ecu and decent injectors (id2000s for example) you can have the car idling at the same AFR's and with the same quality as standard injectors.
https://www.sau.com.au/forums/topic/375532-dyno-tune/#findComment-5990413
what about if it were a r33 gtst, would the z32 be better than a stock afm, at what power output would the z32 be best to use?
https://www.sau.com.au/forums/topic/375532-dyno-tune/#findComment-5990442
no, the Z32 AFM is not better than the stock GTST afm. Both are 3 or 4 wire, hotwire Air flow meters that are 80mm in size.
The Z32 AFM allows for a wider tuning scale but it does zero to add more rwkw or average power etc.
https://www.sau.com.au/forums/topic/375532-dyno-tune/#findComment-5990570
so say for example, i was at a power level between say 200 and 250kw, would using the z32 give the dyno graph a fatter curve or /more accurate or steeper curve than the standard?
https://www.sau.com.au/forums/topic/375532-dyno-tune/#findComment-5990587
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
