It depends personally if you can justify cams about a 1000 and valve springs another few hundred for gains in midrange and slight top end. To me its worth it but other people would rather spend money somewhere else.
  • 11 years later...
Anyone have any experience between the poncam 256 8.5 & the Kelford 246-A 262 9.3? For a basic street setup 25 around 350kw with gtx3076. (back to pump gas now as ethanol is getting too expensive @ about $5.50/l & a hassle for mixing).
Doesn't seem to be a lot of results around for the Kelford?
I don't know a lot about cams with regards to overlap & ramp angles etc but seems like the Kelford is probably better or maybe not much difference?
@SKYMAGGOT Iv got Apexi RB25DET VCT Cams not too sure on the duration but they are 8.9mm lift, got to get them refurbd as they are worn on the corners, cant wait! journal bearing GT3582r with apexi power fc, killer time
Ok, have you run them before? Might be better to get new if they're worn which is unusual?
GT3582r usually means roller bearing-I don't think there's a Garrett version that's JB so could be something else? A lot of people in NZ seem to have the TA3410 JB Garrett.
You just running 98?
1 hour ago, GTSBoy said:
So many people say they have a GTXXYYr when in reality they have a ChinaBay/offbrand copy.
Yep.... and when they yield poor results, Garrett turbos then cop a bad reputation.
FWIW, I have Kelford 244-B (264/272 9.6mm) and a real Garrett GTX3576R Gen 2 with a 1.01 T3 Garrett divided turbine housing. 0.8bar by 4000rpm, makes 437kW at about 7200rpm, rev limiter at 8600rpm. Boost target was 1.8bar but it bled down to about 1.5bar by the redline (turbo is out of puff).
In some shape or form if you have a real Garrett GTX3076 (hopefully Gen 2?) then our compressor maps are identical.
  • Like 1
I have the old 256 poncams ,old gt3076r on factory manifold externally gated. Around 16-17psi on e85 is around 320kw. Very responsive on the street and track. Revs to about 7000rpm. Its more of a 2008-2010 spec era setup only benefit I have is drive by wire.
These days I'd wouldn't even bother with cams unless going for big power(400+kw).
  • Like 1
Patiently waits for that turbo to blow up so you can modernise it haha...
But being a genuine Garrett, I'll be waiting for a while.
  • Haha 1
Every part of your setup is better than mine, I'm doing a new setup on the side but will be early next year sometime before can finish it off, I'm just trying to band aid until then as it feels crap without the E mix
Yeah it's a bit of a band aid until I can sort out a new setup which will be a few months
This is pretty much me, the whole setup is outdated & needs a do over but thought the cams might make it a bit less depressing in the meantime haha
Theoretically a turbo "should" nearly spool the same on either E85 or 98RON, in some regard broscience and brolyticals would say the EGTs are hotter on 98RON thus spool theoretically "should" be better on 98RON.
Yeah it does, just feels a bit flat with less timing, we have 100+ which is 101.5 but the tune is for 98 so could probably pick up a bit with that
Broscience be incorrect there. E85 has superior spool because of the much increased exhaust gas volume from of how much extra fuel has to be added over 98. The extra 25 - 30% exhaust gas volume on E85 has a far bigger effect on the turbine than the higher egts on 98.
I suppose you are correct there with the increase volume, however I am wondering how of a difference one would see.
Might have to do a back to back one day on the dyno just for broscience :D
  • Like 1
I notice a MASSIVE difference on the blue 32 with the 6466, like I mean night and day even on part throttle inputs. I have the 98 vs E85 dyno for it on here.
Pls allow the combustion engineer in the room to correct this.
Ethanol does in fact have a bit more exhaust gas volume than petrol, but it is nowhere near 25-30% extra. The only difference is that ethanol has a higher H:C ratio, so makes more water vapour. For each O2 molecule you use to oxidise a hydrogen, you will create 2x molecules of water. With carbon, each O2 only makes 1 CO2.
While you might use 25-30% more fuel on E85, you use almost exactly the same amount of air to make the same power. Therefore you use almost exactly the same amount of O2, and hence N2 (from the air).
The reality is that the extra water vapour and smaller qty of CO2 really just increases the exhaust gas volume by a few %. Maybe 5. I'm not about to go do the stoichiometry calculations. But, I have recently been doing exactly that for H2 replacement of natural gas in industrial applications and even then, when you're talking about only making water vapour and no CO2, the increase is not as fat as 30%.
  • Like 2
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
